Which ecu fuse do i disconnect for all keys lost reset
Discussion in 'Gen 4 Prius Main Forum' started by Kham, Aug 2, 2024 at 4:06 PM.
  1. Kham
    Kham New Member
    Yesterday
    2019 Prius
    Hi tried the battery method keeps failing the reprogramming for all keys lost so car cant drive without a new key reprogramming so in trying something new which ecu fuse is the correct one to reset the ecu ?..
  2. BiomedO1
    1,499
    811
    SacTown, Ca
    Dealer if you don't have any keys that's already programmed into the system. Bring ownership paperwork and ID. I believe even an automotive locksmith requires that you have at least one programmed key to get into the system to add or delete other fobs.
    If it was as simple as pulling a fuse to program another key fob into your car - car thieves would be doing this all day long..... Dude where's my car....
    Just saying....
  3. ChapmanF
    15,752
    Locksmiths listed on the NASTF Vehicle Security Professional Registry are eligible for the Techstream subscription level they can use to reset with no keys on hand. Of course they're supposed to make you prove it's your car.
    Doug McC likes this.
