Recharge household batteries?
Discussion in 'Fred's House of Pancakes' started by cyberpriusII, Aug 3, 2024 at 1:15 AM.
  1. cyberpriusII
    cyberpriusII Prodigyplace says I'm Super Kris
    1,139
    1,587
    Iowa
    What is the wisdom on AA AAA, possibly C D rechargeable batteries.
    What I am getting on the web is that if you mostly use them for emergencies or the ocassional hike or camping, disposable are still the best bet. ???
    kris
  2. vvillovv
    vvillovv Senior Member
    3,716
    1,313
    NY
    I've got a couple of double and triple A NiMH battery chargers I got them for the digital cameras when a lot of them used 4 double A batts and used them up quickly. 8 packs of AA worked best for my use case.
    It's a timing thing with me. If I'm going to be using the batteries a lot, nearly every day, the rechargables are more cost effective. Triple A rechargables never impressed me all that much. They run out of juice to fast for my taste both Alkaline and NiMH.
    srellim234 likes this.
  3. Leadfoot J. McCoalroller
    7,201
    6,747
    Pennsylvania
    2018 Prius c
    I use AA and AAA rechargeables in lots of places around the house and on the road. In applications like remote controls they go a year between charges. Flashlights a bit less. In my home, there are service flashlights for everyday use and there are separate emergency ones* which I keep loaded with lithium primary cells.
    My shaver runs on rechargeable AAs because I travel all the time and I don't want a lithium battery in the cargo hold of the plane for safety reasons. I carry a tiny USB-powered charger in case the trip lasts longer than the charge- but I've only used it twice in the past decade.
    I strongly recommend Panasonic's "Eneloop" brand. I've tried many and theirs are consistently wonderful.
    *on emergency flashlights: I absolutely love the Toshiba one I got in Japan, wish I'd gotten more. It glows in the dark and it has no power switch. It simply turns on as soon as you remove it from its wall bracket. This design feature is great, because it discourages casual usage and thus preserves battery power for an actual emergency.
  4. Trollbait
    11,573
    Second the Eneloop recommendation. Don't know if Costco still even carries them, but sales were common years ago.
    I used NiMH AA and AAA in remotes and closet lights. Will use them in other lights for planned activities.'Emergency' use I've just been using my phone. Got some alkalines* on hand for flashlights if needed.
    NiMH(and NiCd) have a lower per cell voltage than alkaline. Some gadgets have an alkaline only label for that reason. Depending on the gadget, NiMH might be good enough, and others should stick to alkaline. I'll use NiMH in the programmable thermostats if need be, but not the blood pressure cuff.
    C and D NiMH simply aren't common. Same with the chargers. I don't have enough things that use them to put in the effort to get NiMH for. Seen rechargeable Li-ion in those sizes that were self contained with built is USB charging. Wasn't cheap then to power a 6 cell flashlight though. Will take another look when it is time to replace the alkaline stock.
    *don't keep alkalines in aluminum flashlights. They will off gas over time, and bases don't play well with the metal. Things will swell, and the batteries will get wedged in there. Then you have a pile of Maglights that you occasionally think about contacting the manufacturer for a return.
  5. Leadfoot J. McCoalroller
    7,201
    6,747
    Pennsylvania
    2018 Prius c
    Yeah, I've got a couple of adapters that can drop into the AA slot of many chargers to accommodate a C or D, but haven't used them in years.
    I think I'm down to one item in the house that uses D, and two that use C- kid's toy that she will soon outgrow and my old Yamaha drum machine which somehow I never outgrew.
    A saver-pak of carbon zinc cells every other year is fine for that, and I understand those to be pretty tame in the lanfill.
  6. ChapmanF
    15,752
    In my experience, it has never been worth trying to buy NiMH AAA AA C or D rechargeables at any local brick-and-mortar store; the only choices there have always been puny in capacity compared to what's available somewhere online like batteryjunction.com. I don't know why that is, but it's what I've run into.
  7. Trollbait
    11,573
    Could be physical size concerns with limited shelf space. More mah can end up being a tight fit in some things.
