How to remove the EGR valve/cooler
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by Jdpl76, Aug 3, 2024 at 12:25 PM.
  1. Jdpl76
    Jdpl76 New Member
    Artesia, California
    I need to replace the EGR vavle and maybe the cooler.. The problem is that a tutorial I watched is not the same as my year and I don't see any videos of a layout like my 2016 Prius hybrid.
    Directly to the right of the EGR on my car is the inverter which seems to be in the way. Will I need to remove the inverter to replace the EGR vavle?
    Thank you.
  2. Mendel Leisk
    38,775
    What's the miles? Gen 4 EGR systems have proven VERY butlet-proof. @Raytheeagle did his (did require a inverter shift IIRC).. @jerrymildred did one at the shop he worked at, customer request. To best of my recollection in both cases cleaning proved unnecessary; the systems were still very clean.
    Here's Jerry's post:
    Gen 4 EGR cleaning at 360,000 miles | PriusChat
    #2 Mendel Leisk, Aug 3, 2024 at 2:15 PM
  3. Jdpl76
    Jdpl76 New Member
    Artesia, California
    150,000. I took a putty knife and blocked the path of the EGR took her for a test drive and the problem immediately went away. No more shaking on acceleration.
