Intermittent P0420 Check engine - Catalytic Converter replacement?
Discussion in 'Gen 2 Prius Main Forum' started by Raghav, Jul 28, 2024 at 7:41 PM.
  1. rjparker
    8,034
    4,758
    $288 for a new aftermarket Walker cat makes more sense without risking your eyes, lungs or liver, probably for nothing based on reports and shops who have tried chemical solutions.
    If you think about it, an industrial quality cleaning system that actually restored a bad cat could make more per oem cat as “rebuilt” than the $300-$500 metal recyclers pay for a $1800 oem unit.
    Besides those points, every backyard mechanic knows about the o2 cheat to eliminate the code most of the time. But you still risk engine efficiency or damage running a clogged cat.
    #21 rjparker, Aug 2, 2024 at 3:48 PM
  2. Tombukt2
    9,296
    1,627
    Yeah I wasn't sure whether this was the guy from Slovakia or California apparently California which is just as bad as far as the laws goes with cars and things apparently
  3. Raghav
    Raghav Junior Member
    39
    Ancel handheld tool. Does not provide any more information than the code. Probably tool borrowed at the auto parts store is better?
  4. mr_guy_mann
    mr_guy_mann Senior Member
    3,495
    1,594
    NJ-USA
    Probably not (much) better. Any decent OBD2 scantool can show ECM data for fuel trims, and both Air-Fuel and O2 sensors.
    If you really understand what you're looking at, you can see if the sensors are working correctly and what the converter is doing.
    There is additional testing you can perform with an "OE" level scantool that has bidirectional controls. Again, you need to understand how the system works in order to make sense of the data.
    (If you want to "fully" diagnose this yourself, you'll need to get seriously educated).
    My advice is to look at Short Term and Long Term fuel trims while driving the car. If (ST + LT) stays at 0 +/- 10% under "all" conditions AND there are no engine misfires AND there are NO exhaust leaks anywhere near the cat or O2 sensors, THEN you need a new cat.
