The best and worst years to buy Prius V
Discussion in 'Prius v Main Forum' started by Sudo, Aug 3, 2024 at 11:36 PM.
Tags:
  1. Sudo
    Sudo Junior Member
    Tbilisi
    Currently looking at 2016 Prius V FIVE with 70k miles. (The vin says it’s 2017 but the title says it’s 2016)
    I was wondering if it worth to buy or there might be head gasket issues.
  2. Sudo
    Sudo Junior Member
    Tbilisi
    Vin decoder says it has
    2ZR-FXE, 5JM engine
    vin
    JTDZN3EU3HJ058566
  3. bisco
    49,579
    you have the advantage of the upgraded pistons and rings, but the jury is still out on the cause of the blown head gasket.
    at 70k, you are hopefully in time to clean the egr circuit before problems develop. you can't control past maintenance, but you might want to consider 5k oil changes and more frequent engine coolant changes, or at least ph testing
