  1. Ammon Kegel
    Ammon Kegel New Member
    Idaho Falls
    My Scanner is getting a P0A09 Code "DC/DC Converter status circuit input low". I have just replaced the Power Inverter on my 2008 Prius. IMG_2668.jpg I have attached a thumbnail of the dash and screen errors. I have charged the 12V battery. The car will start and I am able to drive it, but not sure what I need to do here to remove this error. Any help on the next step here would be helpful. Thank you
  2. ChapmanF
    15,784
    There are two electrical wires run between the DC/DC converter (part of the inverter assembly) and the HV control ECU, carrying signals called NODD and VLO, as seen here:
    The P0A09 comes with a three-digit "INF code" that some scan tools can read: either 265 or 591.
    If it is 265, the ECU is complaining about what appears to be an open circuit or ground-short on the NODD wire.
    If 591, it is the same complaint, but about the VLO wire.
    There are separate sections in the repair manual (two or three pages each) with troubleshooting steps for solving either problem.
    Toyota Service Information and Where To Find It | PriusChat
  3. Tombukt2
    9,329
    1,631
    I've had this code before too and my question was and still is input low what input what is the input to the DC to DC converter That's low The hybrid battery voltage the 12 volt voltage or what I think when I have just a change the inverter in an '06 car or something like that to an '09 the last of the Series No problems ever since the car still running great
  4. dolj
    dolj Senior Member
    7,695
    3,897
    Wellington, New Zealand
    The answer is in post #2.
