GEN 1 prius P3106 powertrain code and vehicle stalls
Discussion in 'Generation 1 Prius Discussion' started by blake9809, Jul 8, 2024.
  1. ChapmanF
    15,790
    Toyota's opinion should probably be represented in the thread too (whether or not anyone thinks it's the last word): the check in the gen 1 repair manual (2001 edition, page DI-8, "BASIC INSPECTION", step 1) is "Is the battery positive voltage 11 V or more", and you "charge or replace battery" if it isn't. I'm pretty sure that's the same threshold as in the later repair manuals.
    There are several ECUs in the car that measure their own supply voltages and can give trouble codes if they measure low. The C1241 code from the brake ECU is one example. The thresholds for those codes generally fall in the 8.5 to 9.5 volt range. Remembering, of course, those aren't readings of the battery under no load, but actual voltages seen in operation when a load may be pulling it down.
    Certainly it's never a bad idea to check the battery voltage, and in particular if you have any of the voltage-based trouble codes, it becomes an even better idea.
    Back when I had a gen 1, it typically started ok down to 9 volts or a little less; it would, of course, log the voltage-related codes, but didn't go 'haywire' or present bogus codes or anything. Below 8 volts I'd more often need to jump it or swap in my spare battery, but again there'd be no weirdness after. I had a fair amount of experience with that, as I usually had some half-baked mod project or other in the works and ran down my 12-volt battery more times than I'd have liked.
  2. blake9809
    blake9809 Junior Member
    31
    Minneapolis, Minnesota
    2002 Prius
    SE
    so the EFI relay and fuse were bad. Replaced the EFI fuse and relay under the hood. Car fired right up and idled for a solid 2 minutes and then some magical electrical smoke came from under the hood, car died and got the exclamation mark on the dash. Examined the wires and a wire in the main wiring harness on top of the engine has lost all of its insulation and is a bare copper wire now. Will need to follow this wire through its whole path and replace the one wire, must be a direct short some where.
  3. ChapmanF
    15,790
    Is there enough insulation left visible for you to tell what color it was?
