Boot button
Discussion in 'Gen 2 Prius Main Forum' started by Has Raf, Aug 3, 2024 at 10:08 AM.
  1. Has Raf
    Has Raf New Member
    Thursday
    Stoke-on-Trent, England
    Anyone any idea what this buttons for? It’s on my 2008 Prius T Spirit. I don’t have keyless entry. The door handles don’t have this button. I know the button to open the boot is on underneath where the number plate lights are. IMG_2118.jpeg
    Data Daedalus likes this.
  2. Tideland Prius
    16,170
    That’s the Smart Key System lock button. You can lock the car from the boot.
  3. TMR-JWAP
    TMR-JWAP Senior Member
    6,279
    5,970
    Columbia, SC
    If you do not have that button on the doors, then most likely someone damaged the hatch garnish and replaced it using what they were able to find. No big deal.
  4. Has Raf
    Has Raf New Member
    Thursday
    Yes, this I think.
  5. dolj
    dolj Senior Member
    7,702
    3,900
    Wellington, New Zealand
    That was my thought too but one question, are you sure you have a T-Spirit? I ask because a T-Spirit should have SKS. If you have, this leads to the question, "What happened to the door SKS lock buttons?" Could the T-Spirit be spec'ed without SKS?
  6. Data Daedalus
    Data Daedalus Senior Member
    1,025
    1,185
    Wembley, London
    That’s definitely not a UK spec part. I suspect it probably came from an imported Prius which was scrapped and parted out. I’ve never seen that feature on UK 2nd Gen Prius Tspirit’s and I’ve seen practically hundreds of them since I bought mine 11 years ago.
    iPad ? Pro
    Tideland Prius likes this.
  7. Has Raf
    Has Raf New Member
    Thursday
    IMG_2129.jpeg This is my actual car. UK spec T Spirit. The panel must’ve needed replacing, and a non-UK part was used. It’s also been painted to match, but the match isn’t super, nor the finish, and the paints cracking.
  8. Tideland Prius
    16,170
    Yeah then it must've been a part from somewhere else in the world. For us, that's the lock button for the SKS, in addition to the ones on the front doors. Because you're lacking the sensor and wiring, that button is just a dud and they likely just sourced the wrong part number. Not a big deal I suppose. (other than it shouldn't have been coloured in)
