Moldy smell when fans turn on
Discussion in 'Gen 5 Prius Care, Maintenance and Troubleshooting' started by priusmouse, Aug 7, 2024 at 12:25 PM.
  1. priusmouse
    priusmouse Member
    249
    83
    Long Island, NY
    2023 Prius
    Every time I turn my prius 23 fans on, when starting the car, there is a moly smell lately.
    i noticed that for some reason this only happens when it is parked in front of my garage. It doesnt happen if the car is parked elsewhere, including overnight.
    either way the smell goes away in less than 1 minute. But it is still annoying/gross.
    do i basically need new filters?
  2. ColoradoBoo
    ColoradoBoo Senior Member
    974
    641
    Monument, Colorado USA
    Yes, it's a known issue in Toyota's for years now.
    Master Toyota mechanic "The Car Care Nut" has a video on how to disinfect the A/C system. But, in the meantime, he suggests you turn the A/C compressor OFF when the car is done being used for the day and blowing the fan on HIGH for at least 5 minutes as you are parking it. This dries out the wet insides of the A/C system which can help prevent the nasty smells.
    Also check your cabin air filter, make sure you have a carbon activated one. If it's not, replace with one. (I don't spend the crazy expensive cost of a Toyota OEM filter, I like the Fun Driving charcoal filters they sell on Amazon...for our 2017/2021 Prius, it's $22.48 for 3 of them.
  3. Mendel Leisk
    38,794
  4. ColoradoBoo
    974
    641
    I saw that, Mendel...thanks! Seems to be a common complaint with Yota's around this time of year!!!
    Have you ever done one of those Toyota A/C disinfectant jobs? I never have but if they aren't too hard I might be inclined to clean our 3 Yota's before winter comes.
  5. BiomedO1
    1,507
    813
    SacTown, Ca
    A filter replacement isn't going to take care of this issue. You have mold spores all around you. All they need is a cool, damp, dark environment to grow in. Your AC evaporator is the perfect spot for them.
    1. Check your filter & evaporator drain. Make sure they're not clogged
    2. Place the climate system in manual mode. Temp. 68-72 degrees, fan on low
    Whenever you use the AC, turn off the compressor 5-10 minutes before you reach your destination. That will dry out the evaporator area and prevent mold from forming.
    Hope this helps...
    FYI: That's how I've got my car setup, never any mold smell...
    ColoradoBoo likes this.
  6. bisco
    49,598
    try turning off the a/c a mile or so before your destination
  7. rjparker
    8,052
    4,775
    You need this injected into your condensate line with the cabin filter removed. Works.
