Diesel hybrid, better or worse mpg?
Discussion in 'Fred's House of Pancakes' started by Priipriii, Aug 7, 2024.
  1. Priipriii
    Priipriii Member
    231
    67
    Theres lots of discussions and reasons of why Toyota doesnt make a hybrid diesel, but im curious to know if one were to exist, do you think it would be superior to their atkinsons counter part?
    Maybe a small car like a prius will not benefit as much, but a highlander hybrid or sienna hybrid might have a lot of potential.
    A diesel engine running at low rpms all the time, which is its peak energy efficiency curve. The only difference I would change is not having it turn off and on while driving unless stopped longer than 4 seconds and batteries are mostly full. I know having the engine running continuously mitigates the fuel savings, but at the same, a regular diesel vs a hybrid diesel, a hybrid diesel can have the advantage of running low rpm and having the electricity it produces do all the work of acceleration while the engine just acts as a coasting maintainer and generator. It would be superior in that sense to a regular diesel.
    Now vs an atkinsons, large cars that are hybrid dont gain that much mpg vs their non hybrid version. Toyota is the better of the hybrids because the max theyll put in their big cars is a 2.5L engine. While as their competitor like GM put a 6L atkinsons in their hybrid version of the tahoe, yukon, escalade. Only to gain an increase of like 4mpg while driving in city to a whopping 20mpg. Pathetic. Id imagine a hybrid diesel tahoe would get a solid 30-35mpg or more IF it existed. The diesel version by itself already gets 28mpg on the highway and 21mpg in the city.
    It isnt like diesel hybrids dont exist, theres a very slim few in europe and most notably is the Mercedes e300 diesel electric. Their diesel hybrid gets more than their gas, at 37.7 - 57.7 mpg. Their hybrid gas engine 22.8 - 39.8 mpg. Does this not prove diesel is more efficient to be paired with a hybrid transmission in some cases? Or at least, all diesels would be more efficient if made into hybrid diesels.
    And of course, when an engine is running all the time as a generator, it would make sense to have the battery capacity double or triple of a normal hybrid. That way the extra electricity created while the engine was idling makes up for it not turning off and on as much as say a prius would.
  2. Trollbait
    12,679
    I think the new Hilux has a mild hybrid diesel option.
    The big issue for full hybrid diesels is cost. There is the more powerful motors, larger battery, diesel engine, and the emission controls. Ford had a couple of concepts around when the gen2 Prius came out. They said that would all add $9000 to price. It can work out in places like Europe, because fuel prices and efficiency make diesel more popular to start, and their emissions are less stringent than the US.
    A diesel might work better as a range extender. It can run at high loads all the time, which is where it produces the least amount of NOx. Emissions controls would be cheaper than for a diesel running with variable loads.
    Isaac Zachary likes this.
  3. PriusCamper
    PriusCamper Senior Member
    13,051
    5,304
    Pacific Northwest, USA
    I follow this guy on Tik-Tok who's building electric logging trucks: http://www.tiktok.com/@_edison.motors
    He's putting enormous diesel generators in them and according to the regulators you can use the cheaper dyed diesel fuel because the engine isn't powering the wheels, it's powering the electric motors: Edison Motors
    If you want to talk about a diesel hybrid, this is the one that's most interesting to me.
    His main motivation is he's been waiting for a Tesla semi-truck for 1/2 dozen years and got so tired of waiting he decided to build his own:
  4. Trollbait
    12,679
    If it can use off road diesel, it probably doesn't meet on road emissions.
  5. PriusCamper
    13,051
    5,304
    The point of that particular video was that it's not considered on road emisisons because it generates electricity rather than generates rotational force directly to the driveshaft and in Canada Electric vehicles don't have to pay road tax: Using dyed diesel to save money - TikTok
  6. Priipriii
    Priipriii Member
    231
    67
    While thats very neat indeed, i dont think the cost to produce electricity from fuel compared to charging at home or running straight gas is economical otherwise id do it myself too.
    It says the tesla semi gets 1.7miles per kwh. The most efficient generator i searched up is .166 gal per kwh. Firman H08051. Thats 10 miles per gallon which is pretty good for a semi actually. Normally they get 6.5 per gal.
    Can someone make sure my math checks out, because whats stopping people from running diesel generators and converting cars into hybrid EVs without the need for massive batteries.
  7. PriusCamper
    13,051
    5,304
    It's a bit different with heavy equipment in strip mines and logging because generally you're going downhill when loaded and uphill when unloaded. That's not always the case, but when it is regenerative capacity is significant, especially in mines where you can actually design the hills in a way that optimizes your regenerative capacity.
    There's too many factors to say any of this is completely true, but if you can design your vehicle and road system to take advantage of downhill regen you can do some really interesting things with super heavy weight diesel hybrid or all electric vehicles.
    Also as an aside, this article recently came out: The Cybertruck is more expensive to supercharge than a Ford F-150 costs in gas | Tesla Motors Club
  8. Leadfoot J. McCoalroller
    8,144
    7,645
    Pennsylvania
    2018 Prius c
    Hey fellas, what's going on in this thread??
    Diesel-electric drive has been a thing for railroad locomotives for a very, very long time.
    Isaac Zachary, N4HHE and PriusCamper like this.
  9. PriusCamper
    13,051
    5,304
  10. Trollbait
    12,679
    And the emissions for off road equipment like generators is nearly always more lax than for cars and even commercial trucks.
    These are PHEVs. Edison Motors also has BEV versions of the trucks. Being disconnected from the drive train lets them run the diesel at its most efficient point for extended intervals by charging the big battery. Which offsets the conversion losses series hybrids see, that get worse at higher speeds.
    Nissan makes series hybrid(no plug) cars. With the hybrid szed battery, the engine ends up running at veriable loads like most other cars. They haven't brought them to the US because the EPA highway economy wouldn't be impressive. The i3 REx mpg is worse than some ICE compact cars.
    They switched to series hybrids to reduce costs, and a mechanical transmission for a freight train was impossible. The steam contemporaries were still more powerful. Don't know if the diesel-electrics used less fuel, but did need a lot less people to run, and cost less in maintenance.
    The short comings of mechanical transmissions are why really heavy equipment are diesel electrics. Ships use it for better center of gravity, and turnable prop nacelles are more maneuverable.
    Efficiency isn't the only reason to go hybrid.
  11. Priipriii
    Priipriii Member
    231
    67
    I always preferred the way electrical drivetrains worked vs regular gear boxes. Not just for the durability and less friction losses, but also due to its simplicity. We use them in basically every electrical appliance we have that requires spin. The only limitations id say is the energy losses in converting mechanical to electric and back to mechanical.
    But like you said, running a regular engine to wheels at less effective ratios takes more energy than converting mechanical to electric back to mechnical if the engine is running at peak intervals. Thats why i wonder if its possible to find a middle balance, as diesel electric trains have, of running a motor to the wheels and charging at the same time to save it for when power is needed. Priuses do that already, but in a different way (start/stop/start/stop) vs (engine running at peak efficiency rpms all the time for charging battery continously).
    PriusCamper likes this.
  12. Leadfoot J. McCoalroller
    8,144
    7,645
    Pennsylvania
    2018 Prius c
    I've argued before that the raw simplicity of the Prius power split device contributes more to the fuel efficiency of the Prius than any of the stuff that happens electrically.
    It's a way to couple a gasoline engine directly to the wheels with extremely low loss and enough variability between input and output RPM to allow the gas engine to stay in a nice efficient operating regime.
    The fact that the compensations to allow this are occurring electrically are a matter of convenience- it is easier to do it that way than other ways, but the real raw efficiency earned is by directly coupling the engine to the wheels using very few parts and bearings.
  13. fuzzy1
    10,603
    But does that loophole apply in the U.S.?
  14. fuzzy1
    10,603
  15. bwilson4web
    16,366
    I have a plug-in hybrid, a BMW i3-REx, and it has a two cylinder, modified motorcycle engine. I would have no problem if it were a diesel or Atkinson modified. But this is not high on my list of priorities because 99% of its miles are electric. It actually has to periodically run an automatic cycle to keep it operational . . . much like my emergency home generator that runs ever Saturday morning.
    N4HHE likes this.
  16. PriusCamper
    13,051
    5,304
    Amy BMW modders done upgrade work on i3 generator? If you can share some links I'd love to learn about what's possible.
  17. dbstoo
    dbstoo Senior Member
    1,397
    752
    Near Silicon Valley
    2024 Prius Prime
    XSE Premium
    Hybrids are generally designed to allow two or more flawed technologies to compensate for each other. In the original Prius design, the objective was to use the ultra low pollution Atkinson cycle gas powered engine despite the very low torque that made it difficult to accelerate from a standing start. Getting great mileage was not a goal originally. The electric motor provided the needed torque without extra emissions and the gas engine provided necessary HP to run the generator to top off the hybrid battery. A secondary weakness of the ICE power-train was the extreme emission levels that were common when the catalytic converter was cold. The Toyota design got around that problem by alternating back and forth between ICE and EV modes in such a way that the CAT never got cold and the battery was never over charged or discharged to the extreme.
    So the question is "What flaw in the Diesel power train are you trying to fix?" There are several flaws ranging from soot emissions to the smell of un-burned hydrocarbons. There's the sound of rattling pistons as the detonation takes place within the engine. Is slow acceleration still a problem "off the line"?
    Last but not least is keeping in mind that the Toyota designs were restricted somewhat by the consent decree issued as part of a law suit filed against Toyota by Chevron. Toyota was (essentially) restricted as to the size of the rechargeable batteries that they could use in a car. It was approximately only allowed to have batteries as big as the Prius was using at the time of the lawsuit, and we know that those were pretty small battery packs. That restriction appears to have been dropped.
    #17 dbstoo, Aug 8, 2024
  18. ETC(SS)
    7,350
    Gotcha Beat!
    DBF!!
    Diesel engines in subs were MADE to be a part of a hybrid vehicle nearly from the very start of the technology.
    Fun Fact:
    They were also made to run on renewables like vegetable oil, potentially disrupting the nascent big petrol empire, just reaching it's stride - but THAT is another story! ;)
    One version of....'the other story.'
    The word "diesel" should be capitalized when referring to the engine, BTW...
    #18 ETC(SS), Aug 8, 2024
  19. bwilson4web
    16,366
    This is my go to forum for BMW i3 users: BMW i3 Forum
    Also this YouTube:
    Prices for a used BMW i3-REx are negotiable. Only consider at 2017 or later because they have the larger battery.
    It was an early YouTube video, nearly 10 years ago, that led me to buy my first, a 2014 BMW i3-REx. It remained in service until an ex-wife decided to trade it in on an ICE tow vehicle. Last year, I replaced it with a $15,000, 2017 BMW i3-REx that is my city car. It preserves my Tesla for cross country trips.
    #19 bwilson4web, Aug 8, 2024
    3rd3rd and PriusCamper like this.
  20. BiomedO1
    4,125
    2,167
    SacTown, Ca
    Wouldn't a heavy lumber truck or any semi-trailer truck, beat-up the roads a LOT worse than a small light Prius? Isn't that the argument some states used to penalized more efficient vehicles with additional annual registration fees?
