12v issues
Discussion in 'Prius c Technical Discussion' started by Legogo, Aug 8, 2024.
  1. Legogo
    Legogo Junior Member
    45
    Azerbaijan
    Gents, the car is Prius C Gen 1 2014. 12v battery was swapped with the noname 35a/h (not an AGM)
    Two years ago after installation of the voltmeter I noticed the voltage drops. Aftermarket rearview mirror starts to blink the camera video. If the voltage is ok there are no blinkings
    When the car is on parking mode the voltage is normal
    Once the shift lever changed to any other mode (drive or rear) the voltage drops for 1 unit less
    Measurements from the 12V battery are indicating 1V more than on other power consumers. Checked on Audio head unit plug, rear reverse lights plug and some other consumers - all showing 12,8-12,4V
    14,3-14,4 v are only available on Parking mode or other modes of the shift lever with headlights on
    What can be the reason?
    Here is the video of how and what is happening:
    52,396
    are you having any problems, or just trying to understand how the electrical system works?
  3. Legogo
    45
    Azerbaijan
    The only problem I faced with, during these 2 years while I witness the issue is blinking small display on rear view mirror which shows the video from rear view camera
    I also plan to install the audio system and afraid of the consequences of the low voltage
  4. bisco
    52,396
    how long after installing the new battery did the mirror start to blink?
    is there some place that can load test the 12 volt?
  5. Legogo
    45
    Azerbaijan
    5-6 months until the summer. It was due to overheating during the day and close to night camera started to work fine.
    I got two new cameras now and both of them are working fine only with the headlights on.
