Featured Toyota prius plus 2013 , alot of lights shows up dashboard
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Jass, Aug 5, 2024 at 12:56 PM.
  1. Jass
    Jass New Member
    Monday
    Ireland
    2012 Prius Alpha
    Hi
    I have toyota prius plus or it's called alpha 2013, suddenly road slippery sign comes on dashboard followed by abs sign ,engine management light, battery lights and a lot of warning signs comes on dashboard I am uploading four photos as well, secondly car is not goings into D from N ,if I try to put D on transmission stick it's stays on N and P sign shows up on the dashboard .it's just hailed now. I did try to reset battery by removing battery leads for 10 min and put back on didn't work ,reset hybrid battery, story remains the same. I would be appreciate, if someone can help or was I similar situation
    49,602
    you need to read the trouble codes with a prius aware scanner, like an autel maxi 200.
    in the meantime, check the 12 volt battery health
  3. ChapmanF
    15,795
    Those are not always good things to do before reading the trouble codes, because they cause that information to be lost, and then it can be harder to identify the problem.
    If your lights have come back right away, you are fortunate not to have to wait some longer interval to have the information available again.
    If you have access to a scan tool that can read all trouble codes from a Prius, that would be the obvious next step. If you do not, then in the interim you can get some of the trouble codes (those for the brake / traction / stability system, anyway) like this:
    Blink (a/k/a Flash) Codes – How to. | PriusChat
    It will be good to know at least some of the codes ASAP. However, I will not be surprised if some of the codes you can get, by the blink method, will indicate the presence of other codes you can't get that way, in which case, eventually, a suitable scan tool (or a visit with someone who has one) will be in order.
  4. Jass
    Jass New Member
    Monday
    Ireland
    2012 Prius Alpha
    Thanks will do that
    Thanks will do that
    #4 Jass, Aug 7, 2024 at 5:15 PM
  5. Jass
    Jass New Member
    Monday
    Ireland
    2012 Prius Alpha
  6. Jass
    Jass New Member
    Monday
    Ireland
    2012 Prius Alpha
    Hi
    We Try autel computer diagnostic system , obd read ecu converter faulty we changed four ecu converter from scrapyard didn't work out,
    Than tried bit upper model 16 toyota auris ecu converter, which it read without faults, happy days but it has cost me a fortune 1k to fix main dealer was asking 2k plus the vat
    Thanks god
    And thanks
    For all advice and guidance
    Best of luck
    bisco and Brian1954 like this.
  7. bisco
    49,602
    congrats, all the best!
