Rear door correction entails what, exactly?
Discussion in 'Gen 5 Prius Main Forum' started by NonFormulaic, Aug 8, 2024 at 1:21 PM.
  1. NonFormulaic
    NonFormulaic Member
    55
    44
    San Diego
    Does anyone know what the “fix” is for the rear door safety correction?
  2. Hammersmith
    Hammersmith Senior Member
    1,376
    1,420
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    We don't exactly know yet. From news reports from Japanese press, it appears to be adding a membrane or new seal to the door handle assembly to keep water from penetrating to the switch.
    I'll post the instructions as soon as they become available, but from looking at the instructions to remove the rear door outside handle assembly, it's likely going to be a pretty big job requiring the rear doors to be pretty well disassembled(removing the assembly is listed as step 24).
  3. Blackat
    Blackat Member
    300
    204
    Colorado
    2023 Prius
    Limited AWD-e
    I put some black electrical tape over the button area til it gets sorted
  4. soft_r
    soft_r Junior Member
    71
    43
    Beverly Hills
    2024 Prius
    How about you read the yapper's thread where they show the fixed part? Safety Recall Rear Doors | PriusChat
    It's just below this one that you made. They even link a video showing exactly what goes on
    And like so many yappers have already said on this issue, it's not a big deal. Leave your auto lock in drive feature enabled and your doors will stay shut. Even if they somehow opened while driving, the force from the wind wouldn't allow them to just FLY open, they'd mostly stay close to the body of the car.
  5. Hammersmith
    1,376
    1,420
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    I missed that video in the other thread. Nice to finally know exactly what the fix is. So it looks like the article in the Japanese press about adding waterproofing layers was either mostly incorrect or just incorrectly translated. The fix isn't adding waterproofing layers, it's replacing a part(which is what I always figured they were going to have to do; so the news article back in June confused me).
    And it's as big of a job as I feared. You basically have to tear the rear door apart to get the assembly free(including removing the glass). The instructions say 1.0-1.5 hours, but I wonder if that's for both doors or just one? Probably both, but I'll wait to see the TSB document for confirmation.
    I wouldn't want to do the job myself. Doors can be a PITA to work on. (Says the guy that had to pull apart most of my front doors fairly recently to remove, modify, and replace the door wiring harnesses.)
    Blackat likes this.
