"Automatic" engine braking
Discussion in 'Gen 5 Prius Technical Discussion' started by Paul Gregory, Aug 8, 2024 at 12:39 PM.
  1. Paul Gregory
    Paul Gregory Active Member
    440
    122
    Alberta
    2024 Prius Prime
    XSE
    Several members here have asserted that the Prius Prime has automatic engine braking. I have been skeptical of this claim, not to be obstinate or difficult, but to find out the truth. If it comes down to choosing to let the issue go, for the sake of preserving harmony, sorry, I value the facts over harmony in this case.
    I have just returned from a short vacation in British Columbia, a place with plenty of long hills where I could test that claim. Some hills are fairly steep, and over 20 miles in length, so there was ample opportunity to test the claim of automatic engine braking. I started out in the morning with a full charge acquired over night, and set out on a route with plenty of such slopes.
    Unfortunately, I shall have to remain skeptical of the claim; I experienced "braking" of a sort, but it wasn't engine braking, it was regenerative braking. I even had my windows down, audio system off, and I surely would have heard the engine going into braking mode. I did not, at least not until I engaged braking with the B mode on the shifter. I don't want to call anyone a liar, but those who claimed to have heard it, must be mistaken.
    I don't shirk a consensus lightly, but in this case, they seem to be mistaken. I know I seem to be in the minority, but consensus does not confer truth.
  2. Brian1954
    Brian1954 Active Member
    896
    335
    South Central PA, USA
    Here we go again!
    CooCooCaChoo likes this.
  3. KMO
    KMO Senior Member
    1,546
    431
    Finland
    2023 Prius Prime
    So you've still not managed to reach the condition you're being contrary about - when the car can no longer produce drag by regeneration due to full battery, so must either produce engine drag or nothing. So you did not manage to produce a relevant result.
    If you've never managed to fill your battery you have no relevant first-hand knowledge to agree with or contradict the observations of those who have experienced full batteries.
    I don't understand why you can't grasp the logic here.
    Fred_H likes this.
  4. dbstoo
    dbstoo Senior Member
    1,345
    717
    Near Silicon Valley
    2024 Prius Prime
    XSE Premium
    Well, if you value facts over ego, you need to clean up your post. It has erroneous assertions and assumptions. Surely you know that the overnight charge does not charge the traction battery to 100% SOC. In your post you are making the presumption that you can hear engine braking, even on an engine design with variable valve timing and with CVT in the place of a normal transmission.
    A good way to set your path forward is to abandon the attempt to override everyone else. After all, there were errors in the posts of all the other threads you set up to argue about your pet peeve.
    .... Or is this the AI posting again?
    Brian1954 likes this.
  5. dbstoo
    1,345
    717
    Near Silicon Valley
    2024 Prius Prime
    XSE Premium
    He's using the common tool of the conspiracy theory. He challenges you to prove him wrong, but when you present him with proof he declares you a liar or mistaken. How does he know that you are wrong? Easy, he disagrees with you.
  6. KMO
    KMO Senior Member
    1,546
    431
    Finland
    2023 Prius Prime
    In the hope of increasing knowledge, rather than ignoring it, do we have data on how 'full' 100% is? Not in the sense of SoC, but in terms of how much regen power is available, compared to lower SoC? Is it set at a level where you still have normal regen, or is it already diminished? I've never spotted it diminished from the dash display, but that's not very conclusive.
    I believe this should be clearly visible in Techstream etc, so maybe there's already been G4 observations.
    One more observation - the Predictive EV Drive that the USA doesn't have is keen to shed charge initially, before starting its auto switching to HV mode. (So if your journey starts on a motorway it won't switch to HV immediately if at 100%, but use EV down to 80 or 90%) That could be about increasing regen ability, or it could just be about battery life.
    Fred_H likes this.
  7. ChapmanF
    15,798
    This BC trip must be the one Paul referred to in post #56 of his earlier thread on the same topic (a good thread to review for any newcomer wondering about this one).
    For clarity, when Paul refers to "the claim of automatic engine braking", he specifically means the claim that the car's ability to spin the engine in fuel-cut mode to resist forward motion is not exclusively used when B is selected, but can also be observed when D is selected and the traction battery is too full to accept more regen.
    Drivers who have already observed that happening, many capturing it on OBD-II instruments, may be puzzled at so much attention to the question whether it happens or not. But then, Paul has a Prime, with its much larger battery, so the "battery too full to accept more regen" condition is much less often reached in everyday driving.
    Paul conducted an earlier test, in less-demanding terrain, and reported it in post #53 of that earlier thread. In advance of that test, he had been advised (posts #38, #39, and #50) of ways to conduct that test that would give it the best verifiability and credibility, in case he found himself reporting a result at odds with what others have experienced and often captured on instruments.
    He used none of that advice in that earlier test, choosing instead to report with no quantitative data,
    An alert reader will spot (credit where credit is due, KMO did spot) that Paul's report itself says regen braking continued all the way down, which is a dead giveaway that the necessary "battery too full to accept regen" condition never was reached, and therefore the claim Paul meant to test did not get tested.
    That led to the anticipation around Paul's planned BC trip, in which he would "have a good opportunity for a do-over, and may be able to do it over with more attention to the reproducibility and credibility of his work."
    Which brings us to this thread, in which he has made that trip, again without observing any of the earlier advice on how to conduct an effective test, relying not on instruments but on "windows down, audio system off, and I surely would have heard".
    From this test, Paul reports again having "experienced 'braking' of a sort, but it wasn't engine braking, it was regenerative braking", and so reveals that in this test, also, the necessary condition of "battery too full to accept regen" was never reached, and the claim Paul wanted to test was not tested.
    This is worth drilling into just a little further. If the car is on a steep downgrade, speed being held by regen braking, and then the battery becomes too full to accept more regen, at that moment, without any change by the driver, something different must start happening.
    Regen braking at that moment will cease. If the car applies no other source of rolling resistance instead (such as engine braking), then the car's speed must begin to substantially pick up as soon as the resistance from regen ceases.
    That second alternative is a claim Paul has, in fact, made, in an even earlier thread:
    Paul may be convinced that's what happens when the battery can accept no more regen, and others may be convinced that engine braking is what happens then, but one thing that cannot happen then is that the car just keeps going down the hill the way it was while regen was happening.
    Paul's test here has not reported that he noticed engine braking, and also has not reported that regen ceased and the car's speed then began taking off. Those are two alternative claims about what could happen when the battery's regen capacity is filled, but because that capacity didn't get filled, neither of those claims got tested.
    Fred_H and Brian1954 like this.
  8. dbstoo
    1,345
    717
    Near Silicon Valley
    2024 Prius Prime
    XSE Premium
    Skipped.
    #8 dbstoo, Aug 8, 2024 at 3:22 PM
  9. bisco
    49,605
    it would be helpful to know how much charge the battery had when beginning descent, and how much at the bottom of the hill, and how your speed changed from top to bottom
  10. soft_r
    soft_r Junior Member
    71
    44
    Beverly Hills
    2024 Prius
    OH THANK GOD we needed another thread about this dumb topic. The dozens of B mode threads we already have aren't enough, we need MORE!!!!
  11. vvillovv
    vvillovv Senior Member
    3,732
    1,315
    NY
    If I understand what you're writing, and Gen 5 is different than Gen 4 when in EV mode ( I've read reports that the engine in the Gen 5 Prime starts more often while in EV mode than what's been experienced in Gen 4 ),. than things get even more complicated, since it's not fully known what all the programming thresholds are for engine on in all situations the car can get exposed to.
    It's always a question with Gen 4 as well if someone actually finds a new set of programming thresholds that will start the engine. I think it's be rare for someone to find another one for Gen 4 at this point.
    Both engine on regen as well as EV mode regen are dynamic, but in pure EV without any engine on trigger(s) regen in B mode is a static hard coded value of regen.
    But if the engine starts or the brake pedal is also used while in B mode than regen switches from that static value to its normal dynamic state based on all the parameters at play that make it dynamic.
    I'm not sure that explains what I've understood about regen in the Gen 4 and how I believe it works on a consistent basis, but at least I gave it a shot.
    I think more confusion comes as a result of Primes new bag of tricks in pure EV mode. that can be near impossible to explain to someone that's never experienced them at least once or as most of us can see from reading this and other threads on the subject.
    To get closer to an answer to your question about what regen is limited to,, I've seen regen spike at 80 Amps once for a second or two. I'm sure it can go higher, but I don't know what it's actual hard line is. I've also seen a 100Amp draw in EV mode going up hill on a hwy entrance ramp with the Go Pedal floored, once
    and than also only for a second or two.
    #11 vvillovv, Aug 8, 2024 at 11:22 PM
