Rear axle level sensor
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Revell, Aug 9, 2024.
  1. Revell
    Revell Junior Member
    sweden
    Hello!
    On my rear axle there is this level sensor that has something to do with my head lights. The automatic leveling I believe. There is a plastic-ish bar (see attached picture) that has broken off on mine and I was thinking I'd just replace it with some metal. But the ends of that broken plastic bar don't match up so I suspect that a piece of it fell off when it broke. So I can't use the length of it as reference. Does anyone know the length of that plastic bar? Maybe someone could measure theirs?
  2. Tombukt2
    13,045
    2,338
    Isn't that a clean break are you saying there's a piece that goes on the end of the eye and then goes on the piece of the shank or shaft that's missing that wouldn't seem right so it would seem unbolting the eye and sticking it on the end where it broke off and measuring hole to hole should give you. Just what you need I don't think I have automatic leveling on my Persona I'll look the rain just stopped but I don't think that happens unless you have I'm not even sure what to duall projectors or something
  3. bbrages
    bbrages Member
    164
    47
    St. Louis
  4. Revell
    sweden
    It's a bit of a mystery why it broke. The sensor arm moves freely. And on closer inspection it isn't plastic at all, it's metal. Judging from that picture in your link (thanks by the way :) ) it seems nothing is missing from my bar.
    For anyone else with the same problem: the bar is 59 millimeters long (center of bolt to center of bolt).
  5. bbrages
    bbrages Member
    164
    47
    St. Louis
    You may be able to find this link on ebay/aliexpress. The aftermarket links are made with metal spherical rod ends and look to be adjustable.
