I bought this oil catch can kit .....
Discussion in 'Gen 2 Prius Accessories & Modifications' started by terramir, Aug 9, 2024.
  1. terramir
    terramir Member
    319
    51
    Los Angeles
    What parts do I actually need that air filter looking thing see attached looks more like a motor cycle air filter and I honestly got like at least 234k on my engine but a fairly new cat which I would like to last for ten years lol. So please let me know what I need to use
    terramir
    #1 terramir, Aug 9, 2024
  2. N4HHE
    N4HHE Junior Member
    North Alabama
    What makes you think you need an "oil catch can"?
  3. bisco
    52,355
    deleted
  4. terramir
    terramir Member
    319
    51
    Los Angeles
    Because the 2nd gen is notorious for carbon build up in the intake and the valves coming through the PCV valve
    That's why, one of the 1st things I did 59k miles ago was clean the throttle plate it was black at about 166k miles now there are over 234k miles on it
    V Sport Wagon likes this.
  5. terramir
    terramir Member
    319
    51
    Los Angeles
    I wish I got to see what you said
  6. V Sport Wagon
    V Sport Wagon Active Member
    375
    131
    Southern California
    If you think that's bad, you should see the junk that comes out of a Gen 3. Even on my current Gen 4, the can is full every oil change.
  7. bisco
    52,355
    i immediately thought you had a gen 3 without looking at your car or the forum, because they are so prevalent in that generation.
    is gen 2 a big problem?
  8. Mendel Leisk
    41,870
    Gen 2 takes the PCV gas only from the top of valve cover? Maybe a lot cleaner. Gen 3 takes it from a point near top of block, a few inches below head gasket. And there’s always a lot of “soup” in the intake manifold. There an effective oil catch can “helps”.
  9. mr_guy_mann
    mr_guy_mann Senior Member
    4,086
    1,997
    NJ-USA
    I put a catch can on my 2006. Uses about a quart per 3000 miles. At 5k oil change, I had 4-6 oz of "spooge" to drain in summer. In winter it was always overfull with water (condensate) - had to drain it twice per 5k.
    The intake manifold still looked to have "the same" amount of oil sitting in it after 5 or 10k, so I got rid of the can.
