Drive or not to drive with an hybrid error
Discussion in 'Gen 3 Prius Main Forum' started by Luisbf, Jul 10, 2024.
  1. Luisbf
    Luisbf Junior Member
    Barcelona
    Hi guys
    I know this probably is a very repeated topic, but I didn't find any topic with the same issue I have.
    I am travelling on vacation with my wife, and 1200kms far from home the hybrid battery failed.
    I have one cell with >1v delta from the others.
    The car is loosing power, cutting the A/C and after some time I see the battery is not used anymore, starting to have some dropping in the SOC. I was stopping when it was reaching 20%, erasing the error so the battery charges back even with the fault on it.
    The question is: Is it safe ( or relatively not very high risk) to drive back home in this situation?
    I really don't have how to stop the car to replace the battery and my insurance don't cover the town truck back home that far.
    Another option is to order a couple or cells from eBay and replace it on the street. I did it before, have the tools with me and the only problem would be the waiting for the battery.
    Have you seen anyone driving with the battery fault for some time?
    Regards
    Luis
  2. Tombukt2
    9,381
    1,640
    I drove my generation too about 5,000 mi with the battery that was pretty much in the toilet
  3. bisco
    49,612
    yes, others have reported driving with a bad battery, even resetting the 12v every time they start if necessary.
    i remember having to replace a frozen brake caliper on my old fiat, at the camp grounds we were vacationing at in north carolina back in the day. no fun.
    all the best!
  4. ChapmanF
    15,804
    It would be good for you to post the exact trouble codes being reported, so we can be sure whether the car is only reporting the >1V delta that you think is the issue, or know what issue the car itself is reporting.
    The symptoms you report would also be consistent with overheating of the inverter.
  5. Luisbf
    Barcelona
    Sure
    The codes are P0A80 and P3014.
    Actually the car is an Lexus CT200h 2011. IMG_20240710_141849_677.jpg Screenshot_20240710-140941.png
  6. Grit
    Grit Senior Member
    6,150
    4,058
    Wilkes Land
    Keep driving it. I mean if battery goes bad on the highway, and car fails to a sudden stop, the people who rear ends you will be at fault.
  7. BiomedO1
    1,514
    814
    SacTown, Ca
    You should be able to limp it back home. Just be careful on left turns into cross-traffic and merging onto highways; there's going to be intermittent delays in throttle responses and very slow acceleration. Push it too hard, the car will go into limp mode.
    Good Luck....
  8. Luisbf
    Barcelona
    Thanks all,
    I'm parking the car and taking the train to the rest of the trip, and for the way back I'll drive it back.
    Already have some battery modules going to my next hotel, but I'm not repairing it unless the car gets worse than it is now.
    I'll tell you next week how was the drive back.
    Regards
    Luis
  9. Luisbf
    Barcelona
    Yesterday I drove 100kms to the train station and it was fine. Christmas tree on the dash, but didn't went to full inhibition of emotors, so performance was not that bad and battery was kept withing the normal range.
    I fell confident that it will drive back home safely.
  10. Luisbf
    Barcelona
    Hi all,
    I'm back here to share my experience of driving home with a broken car.
    I managed to get home safely after driving almost 1500 kilometers with the Lexus with the battery in fault mode.
    On this trip, I discovered that when the battery is bad, there are two levels (or more) of system protection.
    In the first level, the car operates almost normally, with only a slight loss of power, perfectly possible to continue using indefinitely.
    In the second level, it's not anymore. When the voltage difference of a cell is greater than 1 volt for a time longer than something between 5 and 10 seconds during acceleration, it completely cuts off the use of the battery, and with that, you lose air conditioning, the brake becomes heavy, the power limitation of the car is high and the battery starts to discharge uncontrollably. In this mode, it is no longer possible to continue driving, and I had to park the car somewhere safe and reset the ignition.
    The trick is to find the driving point in the first level to avoid triggering the second level of protection.
    After a few hours, you find the tricks.
    If you accelerate and the 1v voltage difference remains constant, you have to lift your foot and press the accelerator again, so it doesn't fall into level 2.
    There is also a point when your SOC is exactly 60% where if you keep the accelerator between 30 and 70% the battery is hardly used and the voltage difference stabilizes below 1v and you can drive like this for hours. If you break or lift off, you loose it and have to pedal again until getting to the correct SOC and pedal again.
    The air conditioning at maximum helps a lot to find this point, because if the battery heats up it worsens everything."
    My conclusion is, don't drive the car if a battery module is really bad, showing delta voltage of >1v all the time. But if you have no other way, it is possible to manage to drive as much as you need.
    Once back at home, I replaced the bad module and the car is working great again. Didn't damage anything by using it like it was.
    Best regards
    Luis
    Brian1954 and bisco like this.
  11. bisco
    49,612
    congrats! i'm glad you made it home safely, thanks for the sage advice
