Tags:
  1. Suspenderman
    Suspenderman Junior Member
    Hayesville, NC
    Have rough starts with P0303 and P0304 misfires. Replaced plugs and coil packs. No difference. Replaced fuel injectors, no difference. What next please? 2010 Prius
    49,616
  3. Brian1954
    Brian1954 Active Member
    898
    335
    South Central PA, USA
    How many miles on the car?
    Research head gasket problem on a 2010 to 2015 (Gen 3) Prius.
  4. Suspenderman
    Hayesville, NC
  5. Mendel Leisk
    38,804
    For next time, with misfire codes for specific cylinder(s), try swapping coils around first, see if code changes.
    seconded: need to know the miles.
    Suspenderman likes this.
  6. V Sport Wagon
    V Sport Wagon Member
    246
    87
    Southern California
    Boroscope the cylinders after the car has sat for at least 12 hours, that will tell you all you need to know. It's leading to a head gasket though.
  7. Tombukt2
    9,385
    1,640
    Use the camera like said above and look up at the mating surface of the head to the block you'll see the water droplets they're very easy to see If you just pulled the plugs and look with a magnifying glass you'll see the micro drops of water coolant mix right on the bottom of the plug that's sitting in the engine and look at all four of them can even touch your finger to the insulator and touch it to your tongue if you know what ethylene glycol tastes and smells like and whatnot there's your problem.
  8. bisco
    49,616
    gotcha
  9. Suspenderman
    Hayesville, NC
  10. Suspenderman
    Hayesville, NC
    thank you
  11. Mendel Leisk
    38,804
    They’re usually blown by then; do you know if it’s had a head gasket or engine replacement?
