  1. John Traynor
    John Traynor Junior Member
    Just finished my first hybrid battery swap on my 2012 Prius v.
    With the exception of the lifting, the most challenging part was keeping track of the nuts, bolts and plugs, and working in New Orleans heat.
    I went with OEM NiMH battery because I tend to be risk averse.
    I found it a good opportunity to clean out 12 years of detritus under the battery, inside the fan, etc.
    how did this process go for you?
  2. Tombukt2
    9,400
    1,646
    I just dump all the nuts and bolts in the spare tire well then in a generation 3 I don't think there's any brackets to trim or anything to play with they're pretty easy to get out anyway That's about it
