Auto STOP triggered by Bike Rack
Discussion in 'Gen 4 Prius Main Forum' started by ATHiker, Aug 11, 2024.
  1. ATHiker
    ATHiker Senior Member
    644
    560
    Massachusetts
    Four Touring
    I tried using a hatch mount bike rack on my 2016 for the first time today.
    The car’s parking sensors not only beeped, but the auto braking feature triggers when I put the car in reverse — I literally could not back out of my drive.
    Fortunately, no other gear today so I folded the rear see flat and carried two bikes inside.
    But I would like to use the rack — anyway to disable the problematic sensors?
  2. fuzzy1
    10,602
    Yes, you should be able to turn off that system. I must do so in my '24 RAV4 when using my hitch-mount bike rack, otherwise its backup auto-braking prevents the car from backing up.
    For your '16 Prius, I think it is called Intelligent Clearance Sonar. See your Owner's Manual, pages 348 and 140 of the second edition (March 2016 and later), I didn't look in the first edition (Feb and earlier).
    Toyota Manuals and Warranties | Toyota Owners
    2nd edition: https://assets.sia.toyota.com/publications/en/om-s/OM47B39U/pdf/OM47B39U.pdf
    1st edition: https://assets.sia.toyota.com/publications/en/om-s/OM47A29U/pdf/OM47A29U.pdf
    Tande and ATHiker like this.
  3. ATHiker
    644
    560
    Massachusetts
    Four Touring
    Thanks! I haven’t made the change yet but found the instructions in my owners manual — looks super easy to turn on and off.
