P2237 Code still there
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by AndT, Aug 9, 2024.
  1. AndT
    AndT Junior Member
    Rochester, NY
    Can't get rid of this P2237 code on my 2009, I have read through many of the threads here.
    The code comes back pretty much immediately after resetting, not like most other codes.
    I have changed both O2 sensors, replaced with Denso. I changed the ECM, hoping that would solve it. Put in a used ECM from eBay, so I suppose it could have been faulty.
    Is it time to start chasing wires? Any suggestions on fuses or relays to check? I appreciate any input.
  2. mr_guy_mann
    mr_guy_mann Senior Member
    4,071
    1,989
    NJ-USA
    Where did you get the Denso sensors? I have seen cheap aftermarket (or counterfeit) Air Fuel Sensors cause this code.
    However it is unlikely that two sensors or two ECMs have the same fault.
    So yes, I would look at wiring. P2237 indicates an open in the Air Fuel "sense" circuit (AF+ & AF-).
  3. AndT
    AndT Junior Member
    Rochester, NY
    Thanks for the reply. The Denso sensors came from eBay. So I suppose they could be counterfeit, not sure if there's a good way to know? I will work look closely and test wiring, hopefully I can isolate the issue.
