Eliminating Sway Bar?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by jaster, Aug 12, 2024.
  1. jaster
    jaster Junior Member
    michigan
    2001 Prius
    My 2007 Prius has had some noise issues in the front end. After having the struts replaced (which was needed), I still had the same noise. The shop said the control arms were causing that and they are replacing them today. But as they are working on it they said the sway bar is also contributing to the noise and because the mounts are severely rusted and deteroriated, they recommend simply removing the sway bar. They are saying that it isn't really necessary for this small of a car. They assure me it won't have a negative effect on safety. Does it make sense to remove the sway bar and not replace it?
  2. Tombukt2
    12,924
    2,322
    And this is a real suspension shop doing this work talking about this like this I'm not sure that this is right In the old days my cars that did not have sway bars I'm sure had different springs and other things tuned differently I would imagine to make up for it I can't remember any of those cars it was so long ago but it doesn't sound right Just deleting this sway bar and doing nothing else try it I mean it would seem to me quick maneuvers like swerving in and out of traffic will become a lot more skittish but Prius drivers don't do a lot of that so maybe it's possible I wouldn't say it would become dangerous but may be quite a bit more noticeable that things are a little more lively sloppy if you will. I would think checking out and looking into some suspension sites that really spend a lot of time with this dealing with aftermarket parts deleting various parts I'm sure there are some I haven't looked in years I'll have to look over on Toyota mods tonight and see what the general consensus would be.
  3. Tombukt2
    12,924
    2,322
    I remember why this is not wise to be doing because it's going to make the car a lot wider and lean a lot more especially on the pavement I don't think you're going to appreciate it at all You can try it You will probably tell me it feels unsafe I do find it quite surprising that they're telling you that this would be okay It's kind of funny actually.
  4. PriusCamper
    PriusCamper Senior Member
    12,721
    5,143
    Pacific Northwest, USA
    Danno5060 likes this.
  5. Danno5060
    Danno5060 Active Member
    386
    199
    Wyoming
    It's going to lean over with every corner you make. Even with that small of a car, it'll handle like crap.
    I'm confused on the whole sway bar mounts thing. Is the frame rusted out where the sway bar mounts? Or is it the sway bar brackets, which wouldn't be that expensive (39.00 each)? Or is it the sway bar links (aftermarket $49 with bushings total)?
    In either case, I'd tell the mechanic he can drive without the swaybar in his car if he likes it so much.
  6. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,091
    Columbia, SC
    Unfortunately, if the sway bar actually needs replacing, it's a pretty big job. I don't believe the Gen 2 front sway bar can just be dropped and swapped. There are some interference issues that would add some labor costs.
  7. jaster
    michigan
    2001 Prius
    That's what he was getting at. He said it would involve lifting a lot of things out of the way, including the engine most likely. This is what he told me... "With as small as your car is, you shouldn't be able to notice any difference nor should the car behave any different." They have done work for me in the past and do good work. I may have to take it to the dealer to have it assessed better.
  8. TMR-JWAP
    6,404
    6,091
    Columbia, SC
    In the big scheme of things, it's a Prius.....a little noise? eh....or...
    How many corners you take at full speed?
  9. Tombukt2
    12,924
    2,322
    I think you could change the sway bar like you do the rack in this model I haven't tried it I have to go out and look at the car that's sitting on block that's getting it snatched up pretty soon and off to salvage but it's all sitting up so I can cleanly look under there and take a look I see how to get the rack out I'm wondering if this sway bar can be dealt with and similar manner which won't make it horrible on the labor a little more but if you did it in your driveway well you'd be saving all that It looks doable and I guess if you're going to do that get you a Corolla matrix or whatever bar and it's mounts and bushings and bring it all You could go swipe it off of another car at the junkyard well hopefully in better shape than you have where you are.
    PriusCamper likes this.
  10. PriusCamper
    12,721
    5,143
    It's a pretty sorry excuse to say you have to move too many things to replace a sway bar. It's just a couple boltson the catalytic converter and some front end parts. where they connect to the suspension near the wheels. Any mechanic with basic experience could do this in a couple hours. Just fix it the right way and no more excuses.
  11. TMR-JWAP
    6,404
    6,091
    Columbia, SC
    Nothing on a Michigan, Indiana or Ohio car is ever easy.....it's always the worst possible fastener that breaks also, turning a 2 hour job into a 6 hour job.
    Heck, hit the sway bar with a hammer, it may just fall of the car.
    Tombukt2 likes this.
  12. Tombukt2
    12,924
    2,322
    Yeah in those places usually these kinds of jobs may take the car off the road to be honest about it it can be that bad so it just depends where you are in the mess basically.
  13. mr_guy_mann
    mr_guy_mann Senior Member
    4,040
    1,967
    NJ-USA
    Read the original post again. There was mention of the sway bar mounts being deteriorated. Having the sway bar itself fail is extremely rare.
    Depending on what exactly is "rusted out", the OP may be looking at having to replace the front suspension cradle, or maybe it's just the bushing mounting "clamps" (but the hardware could be seized or eroded).
    Not enough information to make judgement. Lots can go bad up in the salt belt.
    That said, no way would I "delete" the front sway bar.
  14. vvillovv
    vvillovv Senior Member
    4,321
    1,510
    NY
  15. PriusCamper
    12,721
    5,143
    That makes sense for DIY folks... But back when I worked as a mechanic the boss would never accept "I can't get it off" as the answer to a problem. Probably the most important lesson I learned in all my jobs related to working on vehicles ---> You have no choice but to figure out how to remove the old part and put in the new part. There's no other option! This often led to the shop's most challenging moments, where everyone who worked there got involved.
  16. TMR-JWAP
    6,404
    6,091
    Columbia, SC
    When does the price of a sway bar become more costly than the value of the vehicle. Depending on the hourly rate, it may be more cost effective to replace the car than to do what should be a simple job. Maybe the mechanic is actually trying to do him a solid? It's always hard to say without being there or seeing it tho.
  17. PriusCamper
    12,721
    5,143
    My link above is for a $99 performance upgrade via Toyota Corolla sway bar kit, which replaces all three primary front end parts plus bolts and bushings. It'd be absurd to consider it not cost effective and worth more than the value of the car at $99 for parts and a whatever a mechanic cost that isn't intimidated by working on vehicles in northern mid-west that are ruined by road salt.
  18. jaster
    michigan
    2001 Prius
    Yes. It’s the clamps. They said they are too eroded to simply remove and replace the sway bar. I’m getting it back today and will assess.
  19. jaster
    michigan
    2001 Prius
    Just got the car back and they were able to keep everything intact. The sway bar bushings at the mounts were contributing to front end noise and were replaced. It just took them quite a bit of work to get things off because those mounts (clamps) had a lot of rust on them. This is a 2007 Prius that has spent its entire life in Michigan and evidently it's common for any vehicle here to have that level of corrosion and challenge. They replaced the bushings and the sway bar is intact. The control arms and bushings were also replaced (why I took it in) and that helped as well.
    I really appreciate everyone taking the time to offer thoughts and advice. It helped me understand this issue better and I voiced my concern that I didn't want the sway bar removed. Hoping this car can keep on going awhile more.
  20. PriusCamper
    12,721
    5,143
    Grateful that you pushed the mechanic to do the job the right way rather than letting them wimp out and do it the easy/wrong way!
