Cleaned EGR valve, not sure if full circuit is needed. 111k miles
Discussion in 'Gen 3 Prius Main Forum' started by gboss, Aug 12, 2024 at 10:54 PM.
  1. gboss
    gboss Member
    83
    31
    Bay Area
    I cleaned the EGR valve today to gauge whether the EGR system seems bad enough to go through with a full cleaning circuit (cooler, intake, etc.). What do you guys think?
    You can see that it looks caked in carbon before cleaning, but honestly after spraying it with parts cleaner and running a shop rag through it...it was clean and with very little sediment that came off (last 2 pictures). Visually it looked caked, but in reality it was just a thin layer of carbon. I think the revised welding line makes the first picture seem like it is caked on there, but that is just the welding line lightly dusted. Most of the sediment appeared around contact points of the valve/EGR system, the inside wasn't terrible.
    As long as the 96% of the EGR piping is supplying flow, does the system really need to be cleaned? Maybe the cooler is clogged but based on the valve, I'm guessing it's not. What do you all think, should I clean the cooler or just let it be and maybe settle for cleaning the intake while I'm already in here?
    tempImage5q3jf3.png tempImagemwtZqt.png tempImagedSuRiB.png tempImageyoj0im.png tempImageYJj087.png tempImagesgdPt4.png
  2. bettergolf
    bettergolf Active Member
    432
    339
    Sanford NC
    How many miles was on this Valve?
