Brake pedal makes clicking noise stops cruise control
Discussion in 'Generation 1 Prius Discussion' started by John Micheals, Aug 11, 2024 at 8:52 PM.
  1. John Micheals
    John Micheals New Member
    Portland Oregon
    2002 Prius
    My 2002 Prius has been acting up lately. I use my cruise control for most of my city driving and just recently it suddenly will stop working. I have to stop the car, turn it off then on to get it to work again.
    I began to notice that sometimes when I came to a stop the brakes seemed to really kind of suck in to the pedal and as I came to a complete stop the brake pedal would suck in, then a loud clicking sound would happen, then the pedal would release.
    When this happened I noticed the cruise control would stop working and I’d have to restart the car. Pretty sure that was the cause of the cruise control issue.
    Does anyone know what’s causing these issues? Especially regarding the cruise control.
    Thank you!
    John
    Portland OR
  2. Tombukt2
    9,434
    1,652
    Sounds like you need to get a capable scan tool and run a check on the whole vehicle It sounds like you're inverter pump may be acting up. Or possibly your clock spring is breaking communications and making these devices stop working those things need to be looked at if you put your steering wheel in a certain position does the stuff never stop working? This is a generation one and I don't know this particular model that well but the guys that do will be here directly
  3. John Micheals
    Portland Oregon
    2002 Prius
    Thank you! Hopefully this other person will reply to this soon.
    I replaced the inverter in 2016 about 130k miles ago.
  4. ChapmanF
    15,820
    Are there any warning lights on? If the BRAKE or ABS light is on, you can get the trouble code(s) responsible without needing access to a scan tool, like this:
    Blink (a/k/a Flash) Codes – How to. | PriusChat
    It might also be useful to look for trouble codes from the cruise control, but that calls for a scan tool able to read all the codes from a gen 1 Prius.
  5. John Micheals
    Portland Oregon
    2002 Prius
    Hi there!
    there have been no warning lights on since the issue began (over a month ago).
    I went to Oreillys and their OBD reader said A OK.
    However, yesterday the ABS light came on. I restarted the car and it has not recurred.
    Big mystery for me the pedal clicking and the cruise control terminating.
  6. Tombukt2
    9,434
    1,652
    Well if you sit in most Toyotas and you listen carefully usually when you push the brake pedal down just as you touch the brake pedal you should hear maybe a slight click That's the switch that puts the brake lights on in the back and does numerous other things in the Prius tells it when to go into ready mode and all of this and that so maybe there's a problem with that switch if you lean down there lay on the floor look up at the pedal and move the pedal with your hand while looking at the switch you see the little plunger come out I'm assuming your brake lights work You can usually see them in the garage against the door when you push the pedal? I mean in other models of Toyota the pedals are on a shaft and the bushing runs through them and the pedal swivel and move on that shaft I guess it could be possible never seen it personally that the shaft could wear on the pedal assembly and could possibly cause a clicking noise with the slop that that would leave. Never personally seen that I have taken apart a few pedal assemblies when changing from manual to automatic in TE27 Corollas very old cars. Usually the ABS light coming on indoor off The car is seeing something on O'Reilly's scanner may not be the thing maybe try the blink codes the Chapman's talking about and see if that gets you some kind of reasonable information and then someday it might be a good idea to get a scanner that's capable of reading this car not like the one at O'Reilly's there is a list here on this site that goes over scan tools connections etc I'm sure there's something that will work on this older generation one
