Reusable Oil Filter
Discussion in 'Gen 3 Prius Accessories and Modifications' started by AzusaPrius, Jun 2, 2024.
  1. ASRDogman
    ASRDogman Senior Member
    6,124
    3,288
    That restore oil does not work. I'm on my 4th crankcase of it. It's not cleaning the
    build up on the oil rings, like I was hoping for. I have another 5qt container I'll be putting in
    to use it up, then it's back to the Mobil oil. It was worth the try though. Only $5 more a container.
    I will either get a new short block, or remanufactured engine from hybrid pit.....
    I will be less hassle with the whole engine, then just the block.
  2. AzusaPrius
    AzusaPrius Senior Member
    1,960
    841
    Well my engine is not the original, it was replaced with a rebuilt with newer pistons and rings by Hybrid Pit and is only just going to be 3 years old next month.
  3. Jim Swart
    Jim Swart Member
    51
    37
    Portland, OR
    Good choice. I switched over to VRP at my last oil change.
  4. Jim Swart
    Jim Swart Member
    51
    37
    Portland, OR
    Are you speaking of Valvoline Premium Blue Restore Gen 2 or the new Valvoline Restore and Protect?
  5. Mr.Vanvandenburg
    1,082
    378
    2020 Prius Prime
    Oil flow is determined by the oil pump, essentially never changes unless the oil pump goes into relief mode. The steel mesh filter flows no more oil than a standard filter in the same situation.
    The micron rating is not very good. 35 microns is about like the grains in 400 grit sanding paper. Standard oil filters capture far smaller particles.
    Maybe you will find the element never needs cleaning if your engine is in good shape. If it does get filled, it probably isn’t in very good shape, or the air filter leaks.
    Nothing is wrong with the way the KN filter fits in the housing.
    Georgina Rudkus likes this.
  6. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,208
    2,227
    Taylors, SC
    Ever tried the toilet paper oil filter that they sold at state fairs?
  7. ASRDogman
    6,124
    3,288
    I also used 4 oz of seafoam 500 miles before changing the oil 3 times....
    The oil was really black when I drained it each time.
    When I replace the head gasket, the valve train looked almost new.
    The slight brown tint wiped off easily with my fingers.
    I was just hoping it would MAYBE clean up the oil rings....
    It might be, but likely not enough or fast enough. I'm still using about 1.5-2qts of oil
    between changes. Depending on my driving.
  8. ASRDogman
    6,124
    3,288
    New or used??? :eek::rolleyes::whistle:
  9. Georgina Rudkus
    3,208
    2,227
    Taylors, SC
  10. Mr.Vanvandenburg
    1,082
    378
    2020 Prius Prime
    index But too wide for Prius and no cartridge type. Not store bought toilet paper.
    Frantz is good but where could it be put.
