blown head gasket P0301 P0302 P0300 ?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Alain D, Aug 11, 2024 at 11:50 AM.
  1. Alain D
    Alain D Junior Member
    Santa Cruz, CA
    Background:
    * 2014 Prius with 205k
    * bought the car at 150k (was uber) and did right away the EGR cooler (quite clogged)/pipe/valve, new PCV valve and added an Oil Catch Can to prevent future cleanups, cleaned intake manifold (had pool of oil) 4 small holes (also clogged) using @NutzAboutBolts videos
    * spark plugs were changed at ~140k (iridium bosh) by prev owner
    * car never burns any oil (I believe 2014 has fixed ring redesign), changed every 5-6k, and I get maybe half a finger worth in the OCC (milky smell like gas+oil)
    What happened
    * got engine light check for P0301 cylinder 1. cleared it and came back but didn't feel misfire
    * one morning started the car and bad shaking for 15+ sec, strong smell of gas in the exaust
    since EGR should still be clean and newer spark plugs (and unlikely coil going bad especially now that it's 2 cylinder) I thought maybe fuel injector are dirty (gas smell above) so I poured a bottle of Techron Fuel cleaner into my 7gallon filled tank (didn't have luxury of mostly empty tank unlike directions, and syphoning gas didn't work). Decided to drive it one more day about 70 miles.
    * mostly cylinder 1 (oh oh) but also occasionally getting cylinder 2, and even a P0300 (multiple misfire)
    * notice the coolant appear 2" low (keeping an eye now) but not driving the car anymore since it might be a HG instead of dirty injectors ?
    * the few times I noticed shaking was at low rpm or startup
    Read here combustion leak detector (blue -> yellow) might not work on prius so didn't order one. have not checked pressure in coolant tank yet. Thinking of using a boriscope to see inside cylinder 1 and see if I see any coolant but wondering if there something easier I should try first.
    I did a big preventive maintenance with the EGR to prevent this from happening 50k ago and here am I now. I drive an EV now so this is my daughters car, but I don't know I'll ever buy gas car again... :(
    #1 Alain D, Aug 11, 2024 at 11:50 AM
  2. Mendel Leisk
    38,829
    And about 100k too late; head gasket failing.
    A third gen for sale with 150K is almost guaranteed to be a dumped-by-owner scenario. Any evidence of stop-leak product?
  3. Tombukt2
    9,450
    1,655
    Don't fix it get your daughter a realistic car for a young person whatever that might be a Chevrolet Aveo a generation 2 a Chevy bolt maybe there's a lot out there to mull over that's for sure But don't waste time fixing the G3 seriously you'll just be fixing on it all the time moving forward if you enjoy doing that sort of thing then by all means have at it your kids going to want to drive not wait for repairs generally speaking.
  4. rjparker
    8,070
    4,790
    Good advice from Tom. One company near you who has been making a living changing Prius head gaskets for years, now recommends preemptive hg changes before they blow and rebuilt engines after.
    If the car is excellent otherwise and already had a brake booster replacement, you might consider a rebuilt engine from Hybridpit in the LA area.
  5. Mendel Leisk
    38,829
    That’s the easy method. Do it first thing in morning, day after a drive. Or figure out a way to pressurize the engine coolant circuit, look for coolant tears starting at the head gasket. You’ll need a side viewing boroscope.
  6. Alain D
    Santa Cruz, CA
    I didn't think about that... but 55k later seems like a long time for that to old up. 150k/10y is when CA hybrid battery warranties expires (I did throuhgly tested the battery with Dr prius app and rejected other cars) so figure that was why, and price reflected that. I assume the only way to know will be to examine the HG if/when I replace it...
    Don't have sideway boroscope, only down so will have to wait to drip down :)
    Didn't know about brake booster issues... will have to research that before spending time or $$ replacing HG. She loves her prius (I drove it tons before getting an EV when she was in College/abroad) and the gas mileage (~44mpg) is prety close to my Tesla (electricity is very expensive in Cali).
  7. Alain D
    Santa Cruz, CA
    Finally got to try boroscope I bought years ago (for this exact issue I was worry about).
    #1 (misfire) looks very wet (car sat for 4 days) - doesn't smell like gas, and if it was oil I woudl expect to be dirtier ? so maybe coolant... Agrrr.
    #4 (no code) looks rather clean by comparaison though. tiny bit wet looking spot too ???
    #2 (error once) and #3 look totally dry but I realize piston were up so not entire picture and I can't rotate the engine until tomorrow to see...
    spark plugs look indentical (will post pic) other than maybe #1 having a bit cleaner (steam clean) edges... all 4 are very sticky (rust color) on the thread. wonder if he put some anti seize or something.
    Also wondering about the marking H2 B on cylinder head, and if I have the redesigned late 2014 ones and/or fixes ring or if oil consumption going to be the next issue (none so far, 205k).
    #7 Alain D, Aug 13, 2024 at 11:24 PM
  8. rjparker
    8,070
    4,790
    4 is way too clean. 1 is also possible and or has a valve seal dumping oil. Talk to Gasketmasters and Hybridpit for a path forward. I would go with a rebuilt engine or a hand picked JDM engine as a distant second choice.
    This recent diagnostic video proves a severe hg leak and offers reasons to swap the engine rather than just the gasket. It is not a Prius and the mechanic (who is also an engineer) suggests this Jeep model does not commonly blow head gaskets. Gen3 Prius’ (Prii) do have common hg issues and the majority have flawed low tension rings, making a used US engine less desirable.
    #8 rjparker, Aug 14, 2024 at 12:57 AM
  9. Alain D
    Santa Cruz, CA
    yeah 4 looks rather clean to me as well yet no error code (just #1 and once #2).
    Doubt I will put an engine in given I've paid $6k for it 5 years ago so it has served me well, but then again kkb private party list it for about the same price still which is insane... doesn't make sense to put $3k+ into it now. either I do the hg myself or find a shop that can do it for around $1k... time to call around.
    man, so much for Toyota reliability. Prius 10-15 (that's 5 years) has so many big problems... and I though I was ahead doing the entire egr/intake/OCC cleanup (a big job in itself).
  10. rjparker
    8,070
    4,790
    A lot depends on its overall condition. In my Texas market a 2014 is still worth an engine.
  11. Alain D
    Santa Cruz, CA
    not with 205k!
    35k is a very different beast... and $20k for 2014 is insane when you could probably buy new for not that much more and not have gen3 issues...
  12. Mendel Leisk
    38,829
    The first ad above (cargurus) has the VIN, which is good to know: piston ring revision began partway through 2014, and can be determined by the VIN.
    FWIW a 3rd Gen short block currently for sale through Toyota dealership should have revised rings, according to The Car Care Nut.
