Cleaned EGR valve, not sure if full circuit is needed. 111k miles
Discussion in 'Gen 3 Prius Main Forum' started by gboss, Aug 12, 2024 at 10:54 PM.
  1. gboss
    gboss Member
    88
    31
    Bay Area
    I cleaned the EGR valve today to gauge whether the EGR system seems bad enough to go through with a full cleaning circuit (cooler, intake, etc.). What do you guys think?
    You can see that it looks caked in carbon before cleaning, but honestly after spraying it with parts cleaner and running a shop rag through it...it was clean and with very little sediment that came off (last 2 pictures). Visually it looked caked, but in reality it was just a thin layer of carbon. I think the revised welding line makes the first picture seem like it is caked on there, but that is just the welding line lightly dusted. Most of the sediment appeared around contact points of the valve/EGR system, the inside wasn't terrible.
    As long as the 96% of the EGR piping is supplying flow, does the system really need to be cleaned? Maybe the cooler is clogged but based on the valve, I'm guessing it's not. What do you all think, should I clean the cooler or just let it be and maybe settle for cleaning the intake while I'm already in here?
    tempImage5q3jf3.png tempImagemwtZqt.png tempImagedSuRiB.png tempImageyoj0im.png tempImageYJj087.png tempImagesgdPt4.png
  2. bettergolf
    bettergolf Active Member
    432
    339
    Sanford NC
    How many miles was on this Valve?
  3. gboss
    gboss Member
    88
    31
    Bay Area
    I would guess 111k unless the previous owner did a replacement prior to 70k. I have no way of knowing for sure.
  4. ASRDogman
    ASRDogman Senior Member
    6,128
    3,289
    the cooler is the most important part. 2nd are the little holes in the intake
    manifold the exhaust gas flows through.
    Both have tiny passages that get clogged quicker.
    The best idea is to clean it before it gets clogged. Like changing the engine oil
    before it fails.
    gboss likes this.
  5. Mendel Leisk
    38,829
    I’m guessing the only component removed was the pipe between the EGR valve and intake manifold? Or did you manage to have the EGR valve in your hands?
    111k miles, it’s time. Get the whole thing done, intake manifold as well. See top two links in my signature on a phone turn it landscape to see signatures).
    gboss likes this.
  6. gboss
    gboss Member
    88
    31
    Bay Area
    Yup, I’m doing that now. The intake on the block is crazy caked in carbon but I’m not sure what to do because I dont want to hit or spray the injectors (I bet those are covered too if the block itself is soaked in oil and carbon, but I haven’t seen this mentioned in the EGR circuit on the threads). The manifold itself I sprayed with cleaner and rinsed, I'm sure I didn't get everything on the internals but the inlets look fine.
    The gasket on the manifold seems fine but so I guess I’ll just reuse it until 200k, but will replace it if I risk damaging the intake performance.
    #6 gboss, Aug 13, 2024 at 6:28 PM
  7. ASRDogman
    6,128
    3,289
    I use a .22 cal bore brush on me battery powered drill, with gunk. Takes about 15 seconds
    for each port....
  8. gboss
    gboss Member
    88
    31
    Bay Area
    On the head too? I'm not sure how to get that thing clean without hitting the injector or dropping carbon into the chambers,=.
  9. ASRDogman
    6,128
    3,289
    No, I used the bore brush to clear out the egr holes in the manifold.
    I just used carb cleaner with a rag to clean the head intake ports.
    You won't hurt the injectors unless you bang them hard with something hard....
    Your fingers and rag.
