I want to alert everyone of an issue with the auxiliary 12 volts battery in the new Prius prime 2024
Discussion in 'Gen 5 Prius Technical Discussion' started by Kulti, Apr 29, 2024.
  1. Harry94025
    Harry94025 New Member
    Castro Valley
    2023 Prius Prime
    XSE
    No, they only use the GR8 diagnostic/charger. Researching the GR8, apparently most dealerships use this because it provides a receipt-like “ticket” that allows them to submit a warranty claim.
    According to the owner’s manual, there is a criteria related to the “20 hour rate capacity”; if it is low, “even if the time period where the vehicle is not used is a short time, the 12-volt battery may discharge and the hybrid system may not be able to start.”
    In my case, I drove the car on Sunday afternoon and it failed to start on Wednesday morning.
    Reading about this problem here and elsewhere, why aren’t owners making a big protest back to Toyota? I’m planning to contact Toyota, Consumer’s Report, and Motor Trend. Motor Trend should be made aware of this issue with their 2024 Car of the Year!
  2. Harry94025
    Castro Valley
    2023 Prius Prime
    XSE
    Just found this in the owner’s manual. After I last drove the car, it was put on the charger when we got home and I left it overnight since it wasn’t going to be completely charged until 11:30 PM. Removed the charging system at ~8:30 AM the next morning and didn’t try driving it until two days later.
  3. bisco
    49,647
    if you don't drive too often you might need a maintainer
  4. Harry94025
    Castro Valley
    2023 Prius Prime
    XSE
    The dealer texted me this afternoon that they tried to start the car and it didn’t work, a day after they said everything had checked out ok. Very glad that I didn’t listen to them to pick it up yesterday!
    I asked them to see if a larger capacity battery, such as the Truestart 470CCA mentioned by another poster, could be installed. I also bought the NOCO GB40 battery booster in case this happens again…
    AndersOne and bisco like this.
  5. Cc103acs
    Cc103acs New Member
    27
    Connecticut
    2024 Prius Prime
    XSE
    I believe the 12 volt is an AGM battery.
  6. Mendel Leisk
    38,833
    Somebody's gotta do a phantom load test. It's not hard; might get to the bottom of this. It could be excessive phantom load, or the hybrid battery charging causing excessive draw, or a combo of the two.
  7. Tiberius
    Tiberius Junior Member
    Toronto
    2023 Prius Prime
    XSE Premium
    Ok so the battery issue just reared its ugly head. Have a 2023 for about 1 year, battery dead this week. Toyota roadside boosted it, dead again 3 days later. Replaced battery by Toyota (supposedly bad battery as it failed the tests)
    I’m fairly sure I did everything correctly with the battery as per best practices and it still died.
  8. bisco
    49,647
    does canada have the software tsb? don't count on the dealer to know.
    GcinFl likes this.
  9. HacksawMark
    HacksawMark Active Member
    449
    312
    Oregon
    2023 Prius Prime
    XSE
    Did you check to see if you have a tracker tied into your OBD port under the dash?
    PhoS and Templeton like this.
  10. Approximate Pseudonym
    103
    49
    Colorado
    2024 Prius Prime
    XSE Premium
    Not on the '23-24 Prius models.
    Conventional flooded lead acid 12v battery.
  11. purplePriii
    purplePriii Member
    173
    71
    Did anyone post the TSB number or document for this? I looked but couldn't find it
  12. KMO
    KMO Senior Member
    1,560
    436
    Finland
    2023 Prius Prime
    I believe that's referring to this, issued this month:
    T-SB-0054-24
    12V Auxiliary Battery Charge May Deplete When PHEV Charging Cable has an Extended Connection Without Charging
    From here:
    Parasitic battery drain? | Page 4 | PriusChat
    Gokhan and purplePriii like this.
  13. Kulti
    Kulti Junior Member
    us
    2024 Prius Prime
    I went on a two-month vacation and promptly plugged in a trickle charger which will maintain 13.8 volts on the 12 Volt battery. It worked well and no need to jump start. I didn't install a trickle charger for my other 2020 Prius prime Limited for the same two months of absence and the car had no problem in restarting (No parasitic drain like 2024 Prius noticed)
    But the main issue of a dealer installed Dash Cam harness (by CAB Toyota Long Beach CA) wiring was removed of as unnecessary which was the cause of major drain (when Dashcam itself is not installed).
    Beware if the car is locked and left for 2 months without running, you may need the physical key to open the hood to jump start. One may need a factory reset of all sensors to function properly on a fully dead 12 Volt battery.
  14. Gokhan
    Gokhan Senior Member
    4,665
    1,871
    Paramount CA
  15. Roy Peterson
    Roy Peterson New Member
    Richland WA
    2024 Prius Prime
    Today was my turn to have a dead aux 12 volt battery. Car is 2024 Prime XSE Premium 6 months old with 3600 miles. No READY light when going to use car. Unusual feel to brake pedal when pressed. It pushed back firmly. Lights flashing etc and knew it was a battery issue. Installed jump pack on under hood connections to power car up. Fortunately jump pack I was able to reach in trunk area and was NOT stored beneath platform.
    I have a Topdon battery charger/tester which showed about 6.7 volts. Could not do a test of battery since it was under 8 volts. Called dealer for appointment and confirmed they had battery in stock.
    With battery charger hooked up, the voltage started to increase and the battery charge a e up. After a few hours on the charger, I ran the battery test and it came back good battery with CCA higher than the 285 that the battery is rated for. Disconnected the charger, powered car up and got READY indication. With a voltmeter, measured about 13.9 VDC at terminals so the charging system is functional. Called dealer to cancel appointment for now.
    I do to drive short trips with a long one being less than 20 minutes.
    I have an amp clamp meter that measures DC amps. Put the amp clamp on the battery negative cable with a voltmeter on the battery terminals. Installed a light in the baggage compartment so I could read the values with the lift gate closed.
    With all doors closed, the driver display blank and dome light off, the amp reading was 2.5 amps for @ 4 minutes and voltage @ 12.5 VDC. With time the amp reading decreased and the voltage increased. After 12 minutes, the amp reading was @ .28 amps with 12.7 VDC. Both meters auto shutdown so that was the end of this very preliminary testing.
    I was surprised at the amount of current draw from the battery. No surprise if doing short trips the battery would probably not sufficiently charge.
    I’m hoping to perform a more comprehensive test. Probably disconnect the negative lead and install an amp meter in series for better accuracy plus disable auto shutdown on the meters.
    With the number of reports in this forum for a relatively small sample size of 2023-2024 Prime vehicles, seems Toyota has a problem that needs engineering investigation. I don’t leave the charger cable in. Typically disconnect when get notification battery is charged.
    Cheers
  16. Mr.Vanvandenburg
    1,086
    378
    2020 Prius Prime
    These gadgets allow gathering data more easily. There are many kinds and the shunt type that can measure amps. At the least it will notify the soc and amps in real time and store the data for five days. Should never have to find the battery unable to start the car again.
    Search Amazon fir battery monitor. A couple I have are the bm200. Link doesn’t post.
