P0A08 error code
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by whodat, Sep 13, 2010.
  1. whodat
    whodat Member
    117
    Aptos, CA
    Previous thread (with new subject title) on my 06 Prius losing steering and brakes while driving with multiple errors (red triangle, battery, etc.) while braking on steep down hill section of hwy 17 (mountain road). Took car to dealer but dealer could not find the root cause.
    Print out from dealer:
    131297 found code P0A08. dc/dc converter status circuit. checked aux battery-passed load test. Check cable connection from auxiliary battery terminal - cables connections are secure. Checked inverter water pump coolant level and operation-pump is working.
    So I had them replace the 12V aux battery. So far no relapse of this problem with one day driving with the new 12V aux battery. I am not convinced that this is the root cause.
    Galaxee and Patrick Wong had previous threads something about DC/DC converters overheating when the inverter pumps failed - and perhaps that is closer to the root cause of the issue my 06 Prius is having.
    Thoughts?
  2. Patrick Wong
    18,200
    6,479
    I suggest that you inspect the inverter coolant pump yourself, to verify that it is working. This is easy enough to do:
    1. Make the car IG-ON (from IG-OFF, press the POWER button 2x without depressing the brake pedal.) All of the instrument panel warning lights will be on.
    2. Open the hood and look for the inverter coolant pump behind the driver's side headlamp. Listen for the sound of the pump running (should sound like an aquarium pump and you should not hear air bubbles.)
    3. Look at the inverter coolant reservoir and note turbulence in the fluid which shows the fluid is circulating.
    Also note that the original 12V battery passed the "load test". This is why I suggest that owners not bother to pay for this test at the dealer, if there are any questions about the battery just replace it.
  3. whodat
    whodat Member
    117
    Aptos, CA
    I checked the hose between the driver side headlamp and the fuse box and noted some slight vibration when I put my finger on it - so I am guessing (if that's the inverter coolant pump hose) its working.
    Which coolant reservoir is the inverter coolant - the yellow fluid reservoir?
    Thanks
  4. 2009Prius
    2009Prius A Wimpy DIYer
    2,705
    510
    63
  5. gabrielino
    gabrielino New Member
    stuart
    Your car and city caught my eye.
    I just bought a 2006 Prius and I live in Aptos too. I get back there in mid may. Perhaps we can exchange some info?
    gabe
  6. kutcht1
    kutcht1 Member
    305
    82
    Andover, Minnesota
    Question for the original poster or anyone else who has had the P0A08 code. Did you also get a high pitched alarm tone?
    TomK
  7. ozmatt
    ozmatt Active Member
    604
    252
    australia
    Hi Kutch, this is a 14 year old thread so the original poster might not be around! but to answer your question YES! i get the high pitched alarm tone along with P0A08 (and others) randomly every few months, im not 100% sure but think the alarm is part of the brake master warning once the aux battery gets down to about 10 or 11v the brake system has a hissy.
    Matt
  8. kutcht1
    kutcht1 Member
    305
    82
    Andover, Minnesota
    Very interesting ozmatt, in my searching I have found very few people mention the high pitched alarm tone. Mine has not happened again since that first time and I have done nothing except some prodding and pocking around. Seems strange that Toyota would put that system of alerting the driver of something like that and it turn out to be what seems like most times as nothing more than a hiccup.
    TomK
  9. ozmatt
    604
    252
    australia
    Hi Kutcht1
    I guess it's to make you immediately aware that something is very wrong! and potentially dangerous.
    One of our cars was doing this every once in a while and it went on like this for a couple of years believe it or not, turned out the 12v aux battery was actually the cause all along and it hung in nearly dead for years getting worse and more frequent towards the end of its time.
    ..Never trust the 12v aux battery in a Prius because they need so little power to READY detecting a weak aux battery can be very difficult
    Matt
    kutcht1 likes this.
  10. kutcht1
    kutcht1 Member
    305
    82
    Andover, Minnesota
    Thanks again for the response Matt. I will keep a close eye on the 12v this summer and will for sure check things closer to winter! It has not done this since and voltage stays well above 12 volt but battery is over 5 years old now.
    TomK
  11. retirednongeek
    retirednongeek New Member
    Wednesday
    Houston, TX
    Hello! I am hoping even though this an older thread, someone will be able to assist me.
    Our 2004 Prius recently had the BRAKE, ABS, RED TRIANGLE, warning buzzer go off while my wife was just backing out of the carport, so she used another car for her errand instead. A few days later it seems to start and run OK, so I drove a short distance until same symptoms appeared. First had it towed to a repair shop (that had replaced ABS 18 months earlier) and they said it was not an ABS issue, but a low voltage issue. I replaced the 30 month old 12V auxiliary battery and still had low voltage codes, but not as many. From there had it towed to dealership. After 2 days they said after charging the new 12 volt battery, it checked out fine.
    Now, a month later, same problem and warning lights.
    After new battery was installed, I ran the auxiliary battery tests by accessing the diagnostic tools using the multi-function display, and all voltages of the 12 V battery seemed within range (static test, under load, and while charging).
    Now the tests show about 11.5 volts or less, even when charging.
    I checked the inverter/converter coolant pump as described in earlier post, and could only hear a slight hum and feel a slight vibration. Could see no "gurgling" at the coolant reservoir.
    Is it likely the inverter/converter is no longer doing its job? Anything else it could be?
  12. Brian1954
    Brian1954 Active Member
    904
    339
    South Central PA, USA
    If you want help, you need to post the trouble codes that are causing the warning light to turn on. Everyone will just be guessing what your car's problem is until you post the trouble codes.
    #12 Brian1954, Aug 14, 2024 at 1:29 PM
  13. retirednongeek
    Wednesday
    Houston, TX
    Thank you. The dealer report showed error code P0A08 at the time they had car a month ago. See attached copy of report. I'd be willing to invest in a scanner, if I could find one best suited. My knowledge of scanner types, brands, and terminology is pretty limited. Open to any suggestions or recommendations. Does the inverter water pump sound like a possible cause, based on my recent inspection of no turbulence in reservoir?
    #13 retirednongeek, Aug 14, 2024 at 1:57 PM
  14. bisco
    49,652
    check inside the inverter coolant reservoir for fluid motion with the car 'on'.
    it could be that the inverter is not working properly. they are cheap enough salvage if it needs to be replaced.
    it will take more testing to determine the problem. you may need a prius aware scanner, not sure what your shop is using.
    see post #2:
    p0a08-dealer-clueless.151186
    #14 bisco, Aug 14, 2024 at 2:43 PM
  15. retirednongeek
    Wednesday
    Houston, TX
    Thanks. I checked the inverter coolant reservoir for fluid motion while the car was "IG-ON (from IG-OFF, press the POWER button 2x without depressing the brake pedal.)" per second post in this thread. Is this what you meant, or should car be turned on and in "Ready" mode?
    And I checked out the post you linked. I have seen other posts about the Mini CVI being recommended. Is this just the connector for the OBD port, or is it the complete scanner? Any additional info on what would be a good Prius aware scanner would be appreciated. Do not know what type of scanner the dealer used, but I would hope an appropriate one.
  16. dolj
    dolj Senior Member
    7,726
    3,911
    Wellington, New Zealand
    Yes, that is what was meant. The result was? Running or not?
    Mini VCI is just the cable, but they mostly come with a copy of Techstream.
    Nowadays, a good bang for your buck is the Autel AP200. This thread reviews several scanners and leans toward the Autel AP200 for the casual user.
    A genuine Toyota dealer will use Techstream which is the gold-standard Toyota scanner.
    #16 dolj, Aug 15, 2024 at 4:28 AM
    Brian1954 likes this.
  17. retirednongeek
    Wednesday
    Houston, TX
    dolj,
    Thanks for the answers and pointing me to the other thread with so much about Gen2 OBD2 apps. mr_guy_mann's Cliff Notes version post with his summary (and the posts following it) were just what I needed to become intelligent enough to ask a few questions. I am beginning to think this may be beyond my skill level, but we'll see.
    And, in answer to your first question, I could hear the pump making a very small amount of sound (more of a hum), and I could feel slight vibration when I put my hand on the pump and the coolant hose connected to it. I could NOT detect any fluid motion in the reservoir itself, even with the cap removed. Perhaps I need to repeat the test and look more closely.
  18. bisco
    49,652
    ig on is all you need. if you make it ready, wait until the engine shuts down so it isn't creating vibrations in the fluid.
    it's possible that the pump is humming but the impeller is shot
