07 prius fuel pump replacement.
Discussion in 'Gen 2 Prius Main Forum' started by 2000keith, Aug 15, 2024 at 11:59 PM.
  1. 2000keith
    2000keith Junior Member
    usa
    Is there a way to change the fuel pump in the 07 prius?
  2. dolj
    dolj Senior Member
    7,727
    3,911
    Wellington, New Zealand
    If you mean just the fuel pump in an NA-market Prius then, no. You have to change the whole fuel tank to change any of the components like the pump or sender.
    Before doing that, you can check the pump works (or not) and the fuel sender for reasonable (or not) readings at the connector on top of the tank and under the rear seat.
    Search the Gen 2 forum threads (using the Advanced Search option) for the details on those two tests.
