Serious questions about the solar option available in the Prime:
Discussion in 'Gen 5 Prius Main Forum' started by NonFormulaic, Aug 14, 2024.
  1. KMO
    KMO Senior Member
    2,011
    734
    Finland
    2023 Prius Prime
    Even down to the correct colour. ;)
    TGrracie likes this.
  2. Hammersmith
    Hammersmith Senior Member
    2,324
    2,372
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    I'm still salty you guys got yellow and we didn't. lol
    (Though I've embraced the red since then, since I'm slowly switching my interior to the black/red combo.)
  3. hill
    8,921
    Alternatively - there's >90% UV/IR ppf that's typically used solely on glass auto roofs. Pricy - especially if applied to the entire car.
  4. AndersOne
    AndersOne Active Member
    341
    198
    Europe
    2023 Prius Prime
    Mine comes with solar panel and I see it as a playful gimick - similar to eg the seat ventilation theres not much point to calculate whether you get back the cost. Especially as youre forced to buy it anway for the higher trims in Europe.
    I doubt its too much different in the states - while you still have the theoretical option to configure solae yes/no it seems to come down in the end what cars are actually available and where.
    As for the solar panel itself, does anyone have clearer technical details regarding minimal energy that must be generated for the charger to actually charge the battery? Some kind of cutoff?
  5. EVPath
    EVPath Junior Member
    Deerfield Beach, Florida
    If you record the EV range, let’s say it’s at 20 miles or 32 km, then leave it in the sunlight for at least one full day (unplugged), do you see the range increase to 23 miles or more / 37 km? What about if you leave it for 15 days in direct sunlight, like at the airport…do you get a full charge?
  6. MAX2
    MAX2 Senior Member
    1,436
    488
    101
    Third planet from the Sun
    This is fantastic!
    The area of solar panels on the roof of a car does not provide much energy. Most of the light is reflected or heats the panel body. For home use and charging backup batteries, a large panel area of several tens or hundreds of square meters is needed.
    And not all airports are flooded with sunlight for 15 days))
  7. Trollbait
    12,681
    Toyota was saying something like 4 miles a day.
    @fuzzy1 worked out some annual miles from the solar in another thread. In L.A., it was 1100 to 50 miles a year depending on the season.
  8. NonFormulaic
    NonFormulaic Member
    62
    45
    San Diego
    What are the chances of info being spread (erroneous or not) on Google which questions the true safety of long term exposure to whatever due to sitting 5” directly under solar panels? Not worth opting in, even if there’s a 2% chance of this. How might this affect resale….not to mention your previously high functioning brain?
  9. Hotdog453
    Hotdog453 Junior Member
    Ohio
    2024 Prius Prime
    XSE Premium
    My wife just got hers on Friday, and will be a prime (heh pun) candidate for it: drives approximately 35 miles a day round trip, and car sits outside at the office. Very curious to see how it works for her.
    if nothing else it does give a smidgen more headroom inside, compared to the glass roof I think. She had zero interest in the glass roof aspect, and the nerd in me enjoys the idea of the solar roof.
  10. MAX2
    MAX2 Senior Member
    1,436
    488
    101
    A tinfoil hat will help you save your brain, survive all hybrid disasters, and even evil aliens.))
    Bill Norton and AndersOne like this.
  11. Mendel Leisk
    41,901
    Every Gen seems to have its “beads and trinkets” feature(s)?
  12. Bill Norton
    Bill Norton Senior Member
    2,218
    745
    MONW, Ks.
    2019 Prius
    L Eco
    Exactly!
    You don't see black airplanes for this very reason.
    The cabin and all the 'avionics and batteries' (conveniently mounted in the cabin) are much hotter in a black car.
    I posit:
    Black Cars may have more electronic failures due to extreme cabin heating.
    Come on. I had one. (y)
    The most it does is bring in outside air and slowly pass it through the cabin. When that outside air is 100°, nothing is 'Cool'. The cabin is still stinking hot, just not as hot as with no fan.
    Vent shades on the side windows and a windshield shade may do the same function.
  13. hill
    8,921
    Even the gen III had a solar option .... mentioned above. Saw a gen III panel w/ sunroof on ebay for sale recently for the gen III. ($1,000 delivered)
    odd ... that the earlier version was not being banned due to crashworthiness. Maybe they upped the standards?
    Anyway the panel was only available on the highest costing trim. You could either get the panel or you can get electric driver's seat.
    #33 hill, Aug 26, 2024
  14. Trollbait
    12,681
    It was only for running the fan while parked though, which has been an option on other cars. No connection to the traction battery at all.
  15. ChapmanF
    18,546
    It wasn't hard, though, to get it it to charge the 12-volt battery also, which can be quite handy if you sometimes leave the car untouched for long stretches. I've pretty much stopped having to think about coming back to a dead 12-volt (as long as the car was parked outside).
    On a sunny day it'll still run the vent blower too.
    It's about a 60 watt panel in gen 3, so it can pretty much offset the usage of an efficient car fridge, during daylight hours anyway.
  16. Mendel Leisk
    41,901
    So it did charge the 12 volt battery as well? That's a plus. I supposed it'd have to, otherwise running the cabin ventilation fan would be a disaster.
  17. ChapmanF
    18,546
    As delivered, it merely ran the cabin ventilation fan. There was no disaster, because all the power to run the fan when it was doing that came from the panel. The 12-volt battery simply wasn't involved.
    It was not difficult to modify the system to charge the 12-volt battery also. I was not the first or only to do so.
    MAX2 and Mendel Leisk like this.
  18. fuzzy1
    10,603
    In a certain range of reduced light conditions, my 2012 Prius solar-powered ventilation fan would cycle on and off every few seconds. Collect enough accumulated energy to start, but then not enough power to keep running, so shuts down. Lather, rinse, repeat.
    After a bit more dimming, it gave up trying to start at all. With no 12V battery drain, there was never any need to turn the feature off. Except in winter, when it was sometimes very bright but colder outside.
    Mendel Leisk and hill like this.
  19. ChapmanF
    18,546
    I suppose winter (and maybe wildfires) could be the only reason the system even comes with an on/off switch.
  20. fuzzy1
    10,603
    It is possible the system already had a low temperature cutout, but bright winter sun warmed the cabin above that threshold and started the ventilation. I didn't pay enough attention to some odd but seemingly inconsequential behaviors, and no longer have that vehicle to go back and better check things out.
