Has anyone tried replacing the 12 volt battery with a LiFePO4 12.8 V battery?
Discussion in 'Gen 4 Prius Technical Discussion' started by GoodOldBob, Dec 1, 2023.
  1. RandyPete
    RandyPete Member
    178
    58
    Santa Margarita, CA, USA
    2024 Prius Prime
    XSE
    What I am trying to say is that "12.2 volts" is not a battery SOC. It is a bettery voltage.
  2. vvillovv
    vvillovv Senior Member
    3,747
    1,318
    NY
    So basically your nit pickin my use of SOC. You wanna be the first to take a set of Amp reading while 12 volt charging is happening by the Gen 4 and or 5 Prii, so we all can hone in the real 12 volt battery SOC, and I'll promise to never use SOC in a description of only the voltage reading again. Great job.
    #22 vvillovv, Mar 24, 2024
  3. sylvaing
    sylvaing Senior Member
    1,128
    473
    The 13.5 volt is pretty consistent, yes. As can be seen here when the battery was warming up
    And when preheating (or A/C) was turned on (that 13.5V before the drive was 10 minutes long)
    But when charging, the voltage does fluctuate, as can be seen below. It fluctuates around 12.8V.
    RandyPete and vvillovv like this.
  4. GoodOldBob
    GoodOldBob Junior Member
    58
    Mena, AR
    2020 Prius
    L Eco
    An interesting article on Battery University website looks at Lithium Ion batteries. Noting that the duty cycle of 100% charge/discharge is only 300 cycles. Yet, a Prius manages to last 10 years....how do they do it? Seems that if you only partially charge and discharge the Traction Battery, the lifespan is greatly prolonged: up to 18,000 cycles if you only charge to 65% and discharge to 55%....which is why Toyota can confidently warranty a 10 year lifespan on the Traction battery.
  5. sylvaing
    1,128
    473
    It's probably like the Prime. The 100% of the traction battery for EV is actually from 15% to 85% of the traction battery. At 8.8kWh, that's 6.1kWh. Below 15% is reserved for the hybrid mode. Above 85% isn't used to, like you said, prevent battery degradation.
    GoodOldBob likes this.
  6. GoodOldBob
    58
    Mena, AR
    2020 Prius
    L Eco
    Even Android cell phones have caught on:
  7. 2010-Prius
    2010-Prius New Member
    Yesterday
    seattle
    The voltage is important. LiFePo4 battries won't hit 100% charge and will begin to suffer sulfation unless they hit something like 14.8v during charging.
    The guy who mentioned charging system voltage dropped great information. That means that adding any kind of lithium, even with a battery isolator, isn't going to work.
    I almost installed that solution with a standard isolator. I see now that I'm going to need a different solution such as a DC to DC charger added between the regular supply of current, and the isolated lithium battery pack (I'm going to be powering an inverter) however this all definitely answers the question of if you can put a lithium batter into your prius as a starting battery.
    Nope, you can't use a lithium starting battery. You'll mess it up and waste your investment.
    You also definitely can't do it with LiFePo4, because those will take damage during every start since they're made for slow cycling, not fast discharge like lead acid.
    AGM is ok in a Prius. Every time I buy a new 12v starter, that's exactly what comes up in retail matching systems like at Autozone. AGM isn't a true deep cycle battery, it's more or less a non-spillable improved version of lead acid that handles deep cycling better, but not as well as an actual deep cycle battery made for deep cycle applications like solar, running inverters, etc.
  8. ChapmanF
    15,828
    Where will the sulfur come from?
  9. MAX2
    MAX2 New Member
    Monday
    Third Rock from the Sun
    Damn diabolical question))(y)
  10. black_jmyntrn
    black_jmyntrn Senior Member
    1,315
    340
    2013 Prius Plug-in
    I can confirm this!
    https://youtube.com/shorts/iI9Zvs1xlYU
  11. sylvaing
    1,128
    473
  12. sylvaing
    1,128
    473
    How does it handle below freezing charging? Lithium batteries hate it when they are charged below freezing temperatures.
