Removing Air Intake Grill
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by Mike Bradley, Aug 15, 2024 at 6:16 PM.
  1. Mike Bradley
    Mike Bradley New Member
    Yesterday
    2018 Prius
    The grill for the air intake at the base of the windshield gets clogged with leaves and schmutz. There doesn't seem to be a way to remove the grill to clean it and the air box below it. Is there a way, or do we just wait for it to fill up and sell the car?
  2. Mendel Leisk
    38,838
    If it’s sim to Gen 3 there are small plastic pieces at the two ends that have to come off first. If you pop the hood you can remove their fasteners (they have a head you push down to release) then you need to simultaneously pry up on the lower end while pulling/sliding down. Then there’s more under-the-hood clips along the the main piece lower edge: all need to be compressed and pushed/pulled out. Then it needs to be pulled towards you and down, to get the underside tangs to release.
    Removal (of Gen 3) is shown here, hopefully similar enough to help, in video #13:
    Nutz About Bolts Prius Maintenance Videos | PriusChat
    hopefully considering you’re Gen 4 (and my flakey recall) I’m not completely blowing smoke.
    #2 Mendel Leisk, Aug 16, 2024 at 8:27 AM
    BiomedO1 likes this.
  3. BiomedO1
    1,525
    818
    SacTown, Ca
    Welcome Mike,
    I couldn't find a video specific to the gen4 Prius, but the procedures are very similar.
    https://www.youtube.com/results?search_query=prius+cowl+removal+
    I've only gotten as far as removing the access panel for the brake fluid reservoir and use a shop vac.and brush to clean-up the leaves.
    Hope this helps...
