HPS Cold Air Intake?
Discussion in 'Prius c Accessories and Modifications' started by Mikej, Jun 7, 2019.
  1. Mikej
    Mikej Junior Member
    28
    2014 Prius c
    Did anyone installed HPS intake on their Prius C? I looked everywhere and nothing came up. Is there even a specific HPS product for Prius C? Or I have to stick with Injen product? Thanks.
    #1 Mikej, Jun 7, 2019
  2. priusCpilot
    priusCpilot Active Member
    663
    210
    LA
    Injen is the only one to trust and that it actually works.
    CosmicWunderkind likes this.
  3. Christophers
    Christophers Active Member
    269
    105
    Honolulu
    2015 Prius c
    Unless you wanna go straight Jdm intake and get the carbon fiber chamber intakes. I’m currently running the blitz chamber piping with a k&n filter. I was thinking about injen but wanted to get a Jdm intake. Sucks I had to go with a k&n filter only cause able to clean it.
  4. emune
    emune Junior Member
    26
    2016 Prius c
    I have the injen intake works and fits great sounds good too
    Got it from priusZilla
  5. Jumpedinthepriasus
    Jumpedinthepriasus Junior Member
    46
    Ct
    The injen is great, Especially paired with 1.8L corolla Injectors; I have them linked on my information tab on my profile. Have definatly had a mpg increase when pairing the two as well as a increase in torque through out the full rpm range
  6. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,389
    2,370
    Taylors, SC
    I installed the HPS on my 2012 Prius v in 2016.
    I have had no issues. The underhood us cleared for me to install the oil catch can close to the pcv valve..
    The closed filter excludes rodent access.
  7. Jumpedinthepriasus
    46
    Ct
    Hell yeah Brother! Could you link the HPS intake you chose? would love pics if you got any
  8. Jumpedinthepriasus
    46
    Ct
    intake*
  9. Georgina Rudkus
    3,389
    2,370
    Taylors, SC
    Don't know about the Pri just c. I 'll check out the HPS web site.
  10. Jumpedinthepriasus
    46
    Ct
    Bet thanks, I have a 2013 Pri C
  11. NyQuil
    NyQuil Junior Member
    30
    2016 Prius c
    What's this about swapping injectors now? I'm looking to get some more torque out of mine
  12. AzusaPrius
    AzusaPrius Senior Member
    2,151
    911
    Injector swap....hmm I like to use more fuel in exchange for power. (Sometimes)
    Can it be done for the GEN3?
    The only difference is more holes in the injector to spray more fuel, I wonder if there is an injector swap we can do with less holes to save fuel
