Lug nut stuck
Discussion in 'Gen 3 Prius Main Forum' started by The Mighty Mutt, Aug 17, 2024 at 4:40 PM.
  1. The Mighty Mutt
    The Mighty Mutt Junior Member
    Flagstaff, AZ - USA
    2002 Prius
    One of the times my parents took their 2014 Prius to have winter tires put on, the tech that was working on it cross-threaded one of the lug nuts. Forgetting about this when my dad was putting wheel back on, the lug nut tightened down about halfway, but now it won't back out. We tried using intense heat and of course some penetrating oil, all in combination with a breaker bar. We have some high-torque impact drivers, but we're kind of afraid that it might start spinning the lug. One way or another, that lag needs to be changed out. So would it be worth the risk to break out the assault ratchet? Or should we try cutting/drilling the lug nut out? I understand drilling it would require a fancy cobalt bit though. Since the wheel is on it, an angle grinder won't work. Maybe chiseling?
  2. ForestBeekeeper
    ForestBeekeeper Active Member
    723
    282
    Maine
    Chiseling will only serve to beat up a chisel [and likely tear up your knuckles]
    I agree that you need to replace the lug bolt.
    Do you have a sawzall?
    Or a cutting torch?
    The Mighty Mutt likes this.
  3. ChapmanF
    15,832
    I think I might go ahead and break out the impact driver. I'd think about it this way:
    • Maybe it succeeds and gets the nut off the stud. Then I can take the wheel off, and press the stud straight out in civilized fashion, and press in a new stud. Studs are cheap.
    • Maybe it ends up spinning the stud in the hub. Then I'm going to want to replace the hub. Hubs aren't as cheap as studs, but they're not astronomical, and it's money I only have to pay in the unlikely event this happens, and it'll be a good story I can tell.
