check hybrid system warning
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by blenderbender, Aug 18, 2024 at 8:18 AM.
  1. blenderbender
    blenderbender Junior Member
    Pa.
    After getting this warning I discovered the hybrid battery cooling fan was loaded with dog hair on the front side and there was a rodent nest filling up the backside. After cleaning everything out I disconnected the 12v battery and reconnected to reset. The warning disappeared for several weeks but is now back on. My question is.... does this fan run all the time while the car is on or is it intermittent as required, because when I turn the car on I cannot hear the fan running. If I pull the fan out and connect to 12v. and it runs can I assume all is okay or are there other factors to consider? Thanks!
  2. Leadfoot J. McCoalroller
    7,214
    6,774
    Pennsylvania
    2018 Prius c
    Fan is computer controlled. If the computer thinks the battery is hot, the fan should run, and it is a variable speed controller with several steps.
