Dumbledore amends a phrase
Discussion in 'Tesla' started by bwilson4web, Aug 18, 2024 at 12:21 AM.
  1. bwilson4web
    15,557
    An idle day dream while Full Self Driving took me home:
    Autopilot chastity is its own reward . . . and punishment.
    49,661
  3. Trollbait
    11,616
    It isn't about how well it works.
  4. hill
    8,248
    Ahhhh - to abbreviate, it's really about whether or not there is an aptitude (or i should say ineptitude) for appreciating the software's ability? How many hours of training & appreciation for what autopilot in a commercial jet can('t) do? When the commercial version is running as designed yet the operator fails, who does it fall on? afaik the legislators don't eradicate the system when there is operator error.
  5. Trollbait
    11,616
    The aircraft pilot does receive hours of training to learn how to use autopilot and what responsibilities are when using it. Since we aren't requiring that for car ADAS, the systems need robust driver monitoring to counter that lack and general human behavior. Then when it comes to safety systems, we need to be stricter with marketing 'puffery'.
  6. hill
    8,248
    Puffery will likely never die out. Instead we have warning labels on everything. To the 400 lb person who tears off the label and fails to read it that says
    "do not use this chair as a step stool" .... implying that if you do a leg may likely break off a chair & then you'll fall to the ground breaking your neck.
    Should the warnings State all the possible scenarios? I suppose that too could be labeled as a warning failure? The world is chock full of litigious people doing lots of foolish things. Some warning labels are translated into a dozen languages because it's so prevalent ... as well as manufacturers needing to exculpate liability.
  7. Trollbait
    11,616
    We do have laws around what can and can not be said in advertising.
    And maybe corporations shouldn't use terms for names the general public doesn't fully understand, or have videos of the CEO doing the things drivers shouldn't do.
  8. bisco
    49,661
    at least we have liz warren to go after the only bad actor
