Cleaned EGR valve, not sure if full circuit is needed. 111k miles
Discussion in 'Gen 3 Prius Main Forum' started by gboss, Aug 12, 2024 at 10:54 PM.
  1. Mendel Leisk
    38,848
    Excellent pictures of the cooler. Again, worth noting this is at 111k miles. Can’t imagine any “cooling” took place with that. And only pinholes of flow left. It’s patently obvious Toyota rushed that nonsense to market without testing.
  2. gboss
    gboss Member
    102
    35
    Bay Area
    Thanks, yeah they really dropped the ball.
    I tried a 12 hour Oxiclean soak followed a quick rinse of Simple Green and then the pressure washer, but the middle of the cooler still seems clogged with gunk even after blasting it out. The water came through but it must only be through one or two passage ways...can't see any light.
  3. Mendel Leisk
    38,848
    Escalate to lye (sodium hydroxide) solution? Hopefully available in the States, say on Amazon. We got some a few years back for soap making, on Amazon.ca. I noticed it's oddly missing from grocery/hardware store shelves. Apparently used in meth production.
    If you're not doing this: most expedient is to cork one end of the cooler, then only about a cup of solution is needed. A bare wire run through the fins may expedite the solution's ability to penetrate.
    Whatever solution is being used, I've found a one hour soak, then rinse and repeat, to be most effective, just judging from the amount of foaming reaction. It tends to be quite active at first, then subside.
    Stumbled on this US lye source:
    Online Store
    #23 Mendel Leisk, Aug 18, 2024 at 4:04 PM
    gboss likes this.
  4. ASRDogman
    ASRDogman Senior Member
    6,141
    3,295
    You wasted 12 hours.
    Oven cleaner. 30 minutes.. Pressure washer.
    Repeat if needed....
  5. xliderider
    xliderider Senior Member
    7,885
    3,124
    Honolulu, HI
    If lye/sodium hydroxide/oven cleaner is used, follow up rinses should be made using very hot, near boiling water.
    The sodium hydroxide and hot water converts the oils to a soap, which is then dissolvable in water. This should be much easier to blast through with the pressure washer.
    If the sodium hydroxide isn't penetrating into the channels, you might need to drive a stiff, thin wire through as many channels as you can access. You won't be able to get at them all, due to the bends in the cooler inlet/outlet.
    SM-G781V ?
  6. gboss
    gboss Member
    102
    35
    Bay Area
    Thanks for the info and link, I took the wire out of an old wiper blade and managed to jam it through most of the holes after another soak. Blasted it again with pressure washer. Is this good enough? I can see light out of the central holes but I'm guessing light isn't coming out of the sides because of the bend in the cooler. Do you guys think this is good enough?
    That will be my next step but I think I got it mostly clean.
    Very good to know, I probably would have started with this if I had to do it over it again.
  7. xliderider
    7,885
    3,124
    Honolulu, HI
    Regarding the last picture of the cooler. No, that is not good enough. It should be very clean with all visible channels clear.
    SM-G781V ?
  8. gboss
    gboss Member
    102
    35
    Bay Area
    man, I guess oven cleaner / lye it is... it took 3 soaks + 2 5-minute pressure washer blasts to get here.
