Wobbling interior rear view mirror
Discussion in 'Prime Main Forum (2017-2022)' started by Salfed, Aug 18, 2024.
  1. Salfed
    Salfed New Member
    2022 Prius Prime
    Is it normal for rear view mirror to wobble while music is playing/ uneven road conditions? Is there a way to tighten it?
    Also, does lock and unlock buttons on drivers side door supposed to be lit up? Looks strange, that they decided not light the panel up. Or is it just my lightbulbs are out?
  2. Tideland Prius
    16,505
    The mirror likely uses a torx screw so you need a torx screwdriver but be gentle because you don't want to crack the windshield.
    As for the door backlit switches, I think they removed them for 2019 or 2020. 2017-2018 models have backlit for sure.
    Salfed likes this.
  3. Salfed
    Salfed New Member
    2022 Prius Prime
    Thanks, T20 bit worked. Had a little confusion on how to take off the plastic covers. Figured to watch comma ai installation guide.
    Tideland Prius likes this.
