3rd Gen. No low oil indicator
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by 2013Prius3, Aug 17, 2024.
  1. 2013Prius3
    2013Prius3 New Member
    Washington
    Not sure how many people are aware of this/ and or if this has already been discussed here. I just wanna inform and help those who don’t know, these for whatever reason do not have a light or indicator of any kind alerting of low oil!
    At least not on my 3rd gen 2013. Also the temperature light can be hard to miss and these are notorious for overheating due to the headgasket failure. If this happens you are more than likely out several thousand for a new engine. I’m personally looking at changing to Android, As they have a free app that will monitor all the engine and battery vitals. Good luck all and hope this helped at least one person!
  2. Tombukt2
    12,698
    2,269
    That's the game plan when you overheat or mess up one of these generally you should be getting a new engine not just changing a head gasket and all of that messing around these engines have no meat in their design there's no room to machine anything or any of that kind of stuff so once things warp break etc they get replaced not rebuilt or any of that there's nothing on a 2ZZ for the engine rebuilder to work with if you understand that so generally you're buying the center section the reciprocating mass all of that is separate because it's a modular designed engine that's just the way it be.
  3. bisco
    51,561
    i dreampt last night that i had to change the head gasket on my 1970 fiat 124 sedan.
    they planed the head, but the block was warped, and after it was done, the pistons and valves were touching.
  4. Mendel Leisk
    41,008
    Did you find out the hard way?
    What's the miles?
    Grit likes this.
  5. 2013Prius3
    Washington
    I wouldn’t say I found out the hard way as my engine is still running! (Somehow)
    Bought it with 39k and just recently hit 145k.
    Over 100K with just oil changes, brakes front & rear and on my second set of tires.
    I just had my first “major” repair done at 144k.
    Spark plugs changed, bad water pump replaced, EGR cleaned & all the fluids drained & replaced. (Oil, transmission, engine coolant, and inverter coolant) to those of you who have 120k or more I would highly recommend getting your EGR cleaned, especially if your car is sluggish. New plugs also a good idea.
    I'm kinda wishing I would have had the timing cover gasket replaced as it is leaking a bit, but it’s not exactly cheap and my mechanic thinks I will be fine for a while. Just gonna stick with 3-5k oil changes and keep an eye on it. I wish there was a temporary fix like a heat resistant silicone I could put around the outside of the timing cover? Anyone heard of such a thing?
  6. 2013Prius3
    Washington
    Sheesh! Thankfully just a dream! Probably cheaper than the Prius tho!
  7. ChapmanF
    17,783
    In a gen 3 liftback, the indication you get looks like this. It's the triangle light plus an oil pressure message on the MID.
    Still to be careful, though: it is not a low oil level warning. Like in most older cars, it is an oil pressure warning, so the engine is already eating itself a little whenever you see it. The dipstick should be used often to check the level.
    Skiddmore and Brian1954 like this.
  8. Leadfoot J. McCoalroller
    8,016
    7,493
    Pennsylvania
    2018 Prius c
    Most cars don't have one.
    Grit likes this.
  9. Grit
    Grit Senior Member
    6,571
    4,223
    Wilkes Land
    If there’s no sensor to detect low oil, how will Android os install its own sensor onto the the engine block’s engine oil
    Circuitry?
    es
  10. MAX2
    MAX2 Senior Member
    1,436
    486
    101
    Third planet from the Sun
    If the android is placed in the lower part of the engine sump and the video broadcast is turned on.;)
  11. rjparker
    9,896
    6,102
    Believe it or not, these engines don't burn any observable oil for 100k miles plus or minus. So owners get complacent about checking the dipstick and most oil change places including the dealer don't tell you if it was low.
    Change the timing chain cover gasket and the head gasket preemptively. I would also increase the frequency of coolant changes after that repair.
    #11 rjparker, Aug 19, 2024
  12. Mendel Leisk
    41,008
    My take:
    to those of you who have 120k or more 50k I would highly recommend getting your EGR cleaned, especially if your car is sluggish and every 50k thereafter.
    be sure to clean it thoroughly, including intake manifold. And the intake ports.
    And look into oil catch can to reduce the detris introduced by the PCV.
    Also, “professional” cleaning can be a mixed bag: ask pointed questions, request before-and-after pictures. Good pictures, properly exposed and focussed. Better: DIY.
    #12 Mendel Leisk, Aug 19, 2024
