2013 Prius Rear Main Seal
Discussion in 'Gen 3 Prius Main Forum' started by HeerenPrius, Aug 15, 2024 at 8:32 PM.
  1. HeerenPrius
    HeerenPrius New Member
    Thursday
    Iowa
    My 2013 Prius has an inner metal ring inside the rear main seal. See pic. The new rear main seal does not have the inner metal ring. Do I need it? Do I transfer the metal ring to the new seal?
  2. ASRDogman
    ASRDogman Senior Member
    6,144
    3,296
    You can check with Toyota about this. But, if it was there, (behind the seal), you should
    reinstall it.
    PS: Does the metal ring fit inside the seal? Or the outside of the ring?
    #2 ASRDogman, Aug 16, 2024 at 7:37 AM
  3. Tombukt2
    9,530
    1,670
    When I pulled my seal out on my factory 2013 block I didn't see this maybe it stayed in the seal like it supposed to what happened to yours You pulled it out and beat it to death or the seal popped out with the lady slipper or the seal remover properly and this was just laying there behind it? You tell me if it was just laying there behind it make sure it's orientation is correct and see if it fits in the new seal I think it's a steel stiffening plate keeps the seal round which it will stay round but it helps it from the lip getting pushed in too far or something along those lines I think it's supposed to stay in the seal If you look at your parts breakdown for the rear main seal it shows just the seal and no plate then if you were to get the Toyota seal that piece would be inside the seal FellPro or aftermarket people may think that's not needed and that's okay for them to think that because rear main seals has been like that for a long time The stiffener plate made me a Toyota design or a seal manufacturer's design that doesn't have to be if you want it go look at what Toyotas giving you at the parts counter It's a generation 3 so I don't do a lot of looking on these I wouldn't think that would make any difference at all personally in the general concept of the rear main seal which on Toyota's never go bad even the ones built like other round similar lip seals look at ones that go in other cars they don't have that plate generally maybe some newer ones do maybe that's how they're making the seal now and that just fell out when you pry the seal out
  4. Tombukt2
    9,530
    1,670
    When I look at the felpro rear main seal for your car it doesn't even look that thick or that wide the circle where that metal plate fits on that seal felpro and other branded seals aren't even that thick and they're made out of a metal ring with the rubber on the inside of the metal ring to run on the seal where is the Toyota sealed or this one in the picture looks to be rubber over thin metal with that piece of metal going inside of the bottom of the seal Just looks like two different ways to manufacture maybe I would be interesting and seeing what Toyota provides at the parts counter or in the head gasket kit with the rear main seal and all of that stuff included fel pro doesn't fool around I've been using them a long time I mean like since the late '60s and I've used their PT head gaskets in my Toyota since 1970 something all the way up until last year I don't do a lot of gas getting work on modern engines are usually throwaways these days.
  5. amarino
    amarino Member
    116
    86
    88
  6. HeerenPrius
    Thursday
    Iowa
    Thank you for the replies. Yes, the 1st seal was from a Toyota Prius engine gasket set. Ordered another seal from Toyota, and the same thing, no inner metal ring.
