P0A08 error code
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by whodat, Sep 13, 2010.
  1. MAX2
    MAX2 Junior Member
    36
    Third Rock from the Sun
    A 12-volt battery is needed to start the hybrid system.
    After the sign “ready” lights up on the display, the hybrid converter supplies the car’s network with a voltage of 13-14 volts, which is used by the car’s systems and charges the 12-volt battery.
    Is the "ready" light on on your car?
