Engine cooling fan not working, pls help!
Discussion in 'Prius v Technical Discussion' started by MM.87, Aug 19, 2024.
  1. MM.87
    MM.87 Junior Member
    Hi.
    I have a 2013 V w/ 337k miles.
    Engine cooling fan stopped working a few weeks ago. AC is not cold unless the car is moving 30MPH+ and if it is a hot day with a lot of stop and go traffic the high temp indicator will come on, so I stopped turning the AC on since last week. Coolant is boiling/gurgling but no coolant loss. No DTC codes. Fan relays 1, 2, and 3 were tested and they are all fine. A Bi-directional scanner couldn’t turn the fans on. The cooling fans used to be on and on mid-high speed all the time w/ or wo/ AC on. I’m still using the car daily. Please share your experience. Thank you!
  2. MAX2
    MAX2 Senior Member
    1,436
    486
    101
    Third planet from the Sun
  3. rjparker
    9,879
    6,089
    Low speed has both fans in series while high speed has full power to both. Check the power and grounds at the fans with the scanner activating them (car in On rather than Ready) to avoid overheating.
    Since both fans are out based on your testing, I might suspect the grounds.
    Low speed
    High speed
    #3 rjparker, Aug 20, 2024
    MAX2 and Air_Boss like this.
  4. MAX2
    MAX2 Senior Member
    1,436
    486
    101
    Or fuses for supplying 12V to the fans
  5. BiomedO1
    3,137
    1,664
    SacTown, Ca
    I wouldn't be driving that around in rush hour traffic. That's a good way to break something, ie. pop the head gasket or warp the head.
    Check the fuse, then the relays. Swap with another known good relay in your fuse box (ie. headlamp relay). Turn on your headlight, swap fan relay with headlight relay - is the headlights still on? That's how you check relay operations.
    If you can disconnect the fan from the wiring harness, you can use jumper wires to hook the fan directly to a battery. That'll determine if you got bad fan motors or wiring and control circuit issues.
    Hope this helps...
