Help!!
Discussion in 'Gen 3 Prius Main Forum' started by analoggirl, Aug 21, 2024.
  1. analoggirl
    analoggirl Member
    131
    26
    Asheville, NC
    2011 Prius. The main hybrid battery has been changed last year, as well as the ABS system.12v 4 years ago.
    The car won't start. The only thing that shows is the door open sign, when I open the engine there's a little whiny sound on the right side. What's going on?
    Help I'm stuck after surgery
  2. Brian1954
    Brian1954 Senior Member
    2,361
    949
    South Central PA, USA
    Do the interior lights work.
    I am guessing that your 12v battery is low.
    Danno5060 likes this.
  3. Mr. F
    Mr. F Active Member
    389
    263
    Washington
    Yep, I'd check the 12V battery. That little whiny sound is the brake booster pump trying (and probably failing) to build up brake fluid pressure at startup. With a healthy battery that sound would have been a much louder buzz.
    Brian1954 likes this.
  4. Mendel Leisk
    41,808
    Do you have a digital multimeter?
  5. 3PriusMike
    3,100
    2,419
    Silicon Valley
    An analog one would work as well. look at her name :)
    Mike
  6. Mendel Leisk
    41,808
    Nope, digital or go home.
  7. analoggirl
    analoggirl Member
    131
    26
    Asheville, NC
    a friend is here and trying to jump the 12 V, and now the red light for the door doesn't even come on, the whining has stopped, there's no noise nothing. And the brakes are really hard to press down.
  8. analoggirl
    analoggirl Member
    131
    26
    Asheville, NC
    [a friend is here and trying to jump the 12 V, and now the red light for the door doesn't even come on, the whining has stopped, there's no noise nothing. And the brakes are really hard to press down.
  9. analoggirl
    analoggirl Member
    131
    26
    Asheville, NC
    It's not working, I'm looking to see if I have something else
  10. analoggirl
    analoggirl Member
    131
    26
    Asheville, NC
    We're going to get a new multimeter, what should be looking at after we get it?
    we, what should we look for?
  11. analoggirl
    analoggirl Member
    131
    26
    Asheville, NC
    Be out?
  12. Mendel Leisk
    41,808
    Just check the voltage on the battery. A healthy battery should be showing at least 12.6 volts. If it's something like 10~11 volts, it's pretty much toast.
  13. analoggirl
    analoggirl Member
    131
    26
    Asheville, NC
    Thanks. The fact that the brake is insanely hard to press, would that indicate any brake issue? or is that the 12 V still?
  14. analoggirl
    analoggirl Member
    131
    26
    Asheville, NC
    What's the best battery to get to replace? I looked at some videos, and I think I can get my son to change it, it looks pretty simple
  15. analoggirl
    analoggirl Member
    131
    26
    Asheville, NC
  16. Brian1954
    2,361
    949
    A battery from Toyota dealership is a good choice. They last a long time.
    The cheapest that I have found is from Walmart, about $180. Look online for stock a Walmart near you.
    Mr. F likes this.
  17. Leadfoot J. McCoalroller
    8,131
    7,629
    Pennsylvania
    2018 Prius c
    I don't know if you'll find your size there, but Walmart is a great choice for batteries just because they sell a bunch, so you are likely to get a fresh one instead of something that's been on the shelf a year already.
    analoggirl likes this.
  18. ChapmanF
    18,434
    What normally makes the brake not insanely hard to press is an accumulator of brake fluid used to assist you, kept filled to high pressure by a 12-volt electric pump. If there hasn't been power to run that pump, the assist pressure gets used up and, without it, the brakes are insanely hard to press.
    analoggirl, 3PriusMike and Brian1954 like this.
  19. fuzzy1
    10,577
    I'd still try charging the 12V battery first, before moving to replace it.
    Mr. F likes this.
  20. analoggirl
    analoggirl Member
    131
    26
    Asheville, NC
    it wouldn't charge, I ended up replacing it with a Toyota battery
