Help!!
Discussion in 'Gen 3 Prius Main Forum' started by analoggirl, Aug 21, 2024 at 2:31 PM.
  1. analoggirl
    analoggirl Junior Member
    61
    Asheville, NC
    2011 Prius. The main hybrid battery has been changed last year, as well as the ABS system.12v 4 years ago.
    The car won't start. The only thing that shows is the door open sign, when I open the engine there's a little whiny sound on the right side. What's going on?
    Help I'm stuck after surgery
  2. Brian1954
    Brian1954 Active Member
    916
    347
    South Central PA, USA
    Do the interior lights work.
    I am guessing that your 12v battery is low.
    Danno5060 likes this.
  3. Mr. F
    Mr. F Active Member
    379
    235
    Washington
    Yep, I'd check the 12V battery. That little whiny sound is the brake booster pump trying (and probably failing) to build up brake fluid pressure at startup. With a healthy battery that sound would have been a much louder buzz.
    Brian1954 likes this.
  4. Mendel Leisk
    38,875
    Do you have a digital multimeter?
  5. 3PriusMike
    3,008
    2,360
    Silicon Valley
    An analog one would work as well. look at her name :)
    Mike
  6. Mendel Leisk
    38,875
    Nope, digital or go home.
  7. analoggirl
    61
    Asheville, NC
    a friend is here and trying to jump the 12 V, and now the red light for the door doesn't even come on, the whining has stopped, there's no noise nothing. And the brakes are really hard to press down.
  8. analoggirl
    61
    Asheville, NC
    [a friend is here and trying to jump the 12 V, and now the red light for the door doesn't even come on, the whining has stopped, there's no noise nothing. And the brakes are really hard to press down.
  9. analoggirl
    61
    Asheville, NC
    It's not working, I'm looking to see if I have something else
  10. analoggirl
    61
    Asheville, NC
    We're going to get a new multimeter, what should be looking at after we get it?
    we, what should we look for?
  11. analoggirl
    61
    Asheville, NC
    Be out?
  12. Mendel Leisk
    38,875
    Just check the voltage on the battery. A healthy battery should be showing at least 12.6 volts. If it's something like 10~11 volts, it's pretty much toast.
  13. analoggirl
    61
    Asheville, NC
    Thanks. The fact that the brake is insanely hard to press, would that indicate any brake issue? or is that the 12 V still?
  14. analoggirl
    61
    Asheville, NC
    What's the best battery to get to replace? I looked at some videos, and I think I can get my son to change it, it looks pretty simple
  15. analoggirl
    61
    Asheville, NC
  16. Brian1954
    916
    347
    A battery from Toyota dealership is a good choice. They last a long time.
    The cheapest that I have found is from Walmart, about $180. Look online for stock a Walmart near you.
    Mr. F likes this.
  17. Leadfoot J. McCoalroller
    7,237
    6,784
    Pennsylvania
    2018 Prius c
    I don't know if you'll find your size there, but Walmart is a great choice for batteries just because they sell a bunch, so you are likely to get a fresh one instead of something that's been on the shelf a year already.
  18. ChapmanF
    15,865
    What normally makes the brake not insanely hard to press is an accumulator of brake fluid used to assist you, kept filled to high pressure by a 12-volt electric pump. If there hasn't been power to run that pump, the assist pressure gets used up and, without it, the brakes are insanely hard to press.
    3PriusMike and Brian1954 like this.
  19. fuzzy1
    10,254
    I'd still try charging the 12V battery first, before moving to replace it.
    Mr. F likes this.
