Broken axle or drive shaft?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Kapcreations, Aug 21, 2024.
  1. Kapcreations
    Kapcreations New Member
    Phoenix, USA
    Daughter sent me a pic of her gen 2, with a broken axle or drive shaft.
    drivers side.
    2006.
    What am I looking at? And does someone have a part number?
    it appears to be half of a shaft if that helps
    The picture was taken on the driver side of the car, standing at the mirror, facing the front of the car.
    rack and pinion?
  2. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,093
    Columbia, SC
    steering rack.
    The transaxle shaft is the shaft just a bit further back in the photo, about 2x the diameter
    new ends are available on Rock Auto pretty cheap...
    #2 TMR-JWAP, Aug 21, 2024
  3. Tombukt2
    13,336
    2,401
    I'd probably put a rack end and an outer tie rod in on that side just because count your threads showing remove behind the inner boot at the rack end inner joining point and then withdraw that and you can measure the length that the two pieces need to be so when you put them in your alignment will be within a 16th of an inch or so which my alignment guy tells me it's very close when I bring my cars to him because this is how I do this usually my alignment guy puts the heads on the front and tells me I'm so close it's not worth adjusting until tire change time just because.
  4. Danno5060
    Danno5060 Active Member
    393
    201
    Wyoming
    That's the inner tie rod, P/N 45503-47030 (but check this part number for yourself. I make no guarantees).
    You're going to need a front end alignment when this is replaced. Perhaps the best would be to have the shop that does the alignment do the repair - if you can find one that's trustworthy.
    #4 Danno5060, Aug 22, 2024
