Should the “Cooling Performance of the Hybrid Battery is Low” warning stay on after cleaning?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Rich Fife, Aug 21, 2024 at 12:43 PM.
  1. Rich Fife
    Rich Fife New Member
    Yesterday
    My wife's 2015 Prius threw this warning about a week ago and I removed about 1/4 inch of lint from the filter. She doesn't drive much.
    Does that warning go off by itself? Can/should I clear it with tech stream? How long does it take?
  2. Mendel Leisk
    38,866
    Did you clean the fan and the ductwork leading to it? If you had that much link on the inlet filter, the rest is likely pretty snowed in as well.
    See video 21 here:
    Nutz About Bolts Prius Maintenance Videos | PriusChat
    But do take a look at this first:
    HV Battery Fan Cleaning | PriusChat
    ^ in a nutshell: no need to remove rear seat.
    Also, you CAN clean the fan without removing it; just getting down to it, but leaving it plugged in and bolted down, you can clean it fine say with Q-Tips. Don't make more work for yourself.
    #2 Mendel Leisk, Aug 21, 2024 at 4:29 PM
  3. Rich Fife
    Yesterday
    Thanks! Do you happen to know if the “Cooling Performance of the Hybrid Battery is Low” warning stays on after cleaning? Is there a time delay or does it go right off?
  4. Mendel Leisk
    38,866
    Not sure. I suspect it'd go away after you've driven a bit, after cleaning fan and ductwork. Assuming that's the issue. It often is.
    So the filter you cleaned is right at the seat back, at the air intake grill for hybrid battery?
  5. ASRDogman
    ASRDogman Senior Member
    6,154
    3,304
    If the fan is/was clogged, the battery may be clogged.
    You might have to take the top off and blow out the battery, in reverse, toward the fan.
    It could be blocked between the battery modules. That's why the warning won't clear.
    Have you tried unplugging the 12v battery for several minutes.
  6. Mendel Leisk
    38,866
    Are you regularly transporting pets?
  7. MAX2
    MAX2 Junior Member
    57
    Third Rock from the Sun
    Afterwards, clear the DTCs to reset the learning values even if no DTCs are stored.
