2016 Prius transmission fluid change
Discussion in 'Gen 4 Prius Main Forum' started by Al h, Aug 22, 2024 at 10:10 AM.
  1. Al h
    Al h Junior Member
    33
    Nj
    Hello,
    Regarding the transmission fluid, they say it lasts the life of the car, but do you guys think it should be changed? I have 160k.
    Thx in advance.
  2. BiomedO1
    1,532
    822
    SacTown, Ca
    IMHO, it should be changed at least every 100K miles. Contaminate concentration builds up over time, chemical structures change through hot and cold cycling, age of fluid, to name a few. Let's face it, the OEM only cares about the car lasting past it's warranty period. That's their definition of lifetime, IMHO. Everything else attributed to their brand name is gravy.
    If you do the change yourself, the cost is around $75 using OEM parts and fluid. I consider that cheap insurance every 100K miles.
    Just my 2 cents......
  3. Mendel Leisk
    38,866
    Takes an hour or two. Four quarts of Toyota ATF WS and replacement washers will set you back about $50* USD. My preference is to do it around one year or 10,000 miles, but no time like the present. There's a link in my signature with some third gen tips, still relevant (on a phone turn it landscape to see signatures). Torque values are higher for the fill/drain bolts with gen 4, not sure why (see attached).
    * That might be out of date, seems the price of the fluid has jumped of late.
