AutelAP 200 fail!!
Discussion in 'Gen 2 Prius Technical Discussion' started by Tombukt2, Aug 22, 2024 at 8:01 AM.
  1. Tombukt2
    9,577
    1,675
    All tells Maxi app AP200 app apparently is not working across the boards and some kind of Android 11 update apparently this is affecting people across the spectrum of devices doesn't look like it's a device problem It's an Android problem so if you update or have updated your software and it's not working if you can revert to the old which can probably can't do you're screwed basically my white AP200 is a brick as of right now the AP 2500 works but it has no brake bleeding capability and other things so it's just a piece of well trash I guess anyway I do have Toyotas software so it's not a huge issue for me but just letting any of y'all know if you haven't seen it yet and maybe issues.
    49,682
