Featured Tesla Semi crashed and caught fire. I-80 closed for a day
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by dbstoo, Aug 22, 2024 at 5:17 PM.
  1. dbstoo
    dbstoo Senior Member
    1,355
    724
    Near Silicon Valley
    2024 Prius Prime
    XSE Premium
    A Tesla Semi was apparently returning to the Tesla giga factory in Nevada for a fresh load of cargo when the vehicle ran off the road. These electric only Semi-trucks are frequently used to ferry batteries to the Fremont factory. In this case there was no trailer on attached to the tractor.
    Cal Trans spent most of the day cooling the battery pack below ignition temperatures before trying to tow it away. Elon iMusk is fond of pointing out that normal ICE sedans have fires too. I don't recall too many of them needing a day to cool down enough to transport the carcass away from the scene.
    More information here: A Tesla Semi crashed and caught fire on a California highway - The Verge
  2. Leadfoot J. McCoalroller
    7,229
    6,780
    Pennsylvania
    2018 Prius c
    *sounds of insurers loading and cocking their actuaries*
  3. fuzzy1
    10,247
    I'm remembering some diesel trucks burning so completely that there was nothing much left to need much cooling down. Just drag away the axles, pry or peel up any rivulets of melted / re-solidified aluminum, sweep up some other debris, then quickly repave the damaged pavement before reopening the road.
    In one case of a fuel tanker climbing I-82 towards Manastash Vista and rear-ending another fuel tanker parked disabled on the shoulder, while the front driver jumped to safety, there wasn't enough of the rear cab left to even locate a driver's body, it was fully cremated. Though that fact that both rigs were loaded fuel trucks did cause the wreckage to burn more completely than normal.
    #3 fuzzy1, Aug 22, 2024 at 5:40 PM
  4. Trollbait
    11,626
    VWs using magnesium engine blocks required a back hoe to come in, dig a hole, and then bury the entire burning car.
    A couple here burned under overpasses, requiring major repairs to those bridges.
    Edit: There are car sized fire blankets available to contain the smoke, and help smother the fire. Plus, they are working on nozzles that go under the vehicle to spray the battery from underneath. Less effective on something this big, but the concerns of EV fires are being addressed.
    Salesforce B2B Commerce
    #4 Trollbait, Aug 22, 2024 at 5:52 PM
